Home > Technical (L322) > transfer box replacement woes |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
Has the selector shaft attempted to be moved with the tail-shafts removed, turning the flanges at the same time? Is does sound as though there is a problem with the TC.
15th Dec 2018 8:54pm |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
So, to further this we've spent some time on it today before my pal goes under the knife.
16th Dec 2018 7:21pm |
Here is the transfer case section from the D4 wsm. It shows how the range change/clutch engagement motor and shafts work.
16th Dec 2018 8:58pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
Replace the duff bearing in your transfer box? I dont know how deep is buried or what your facilities / abilities are. BMW i3 Electric Car
16th Dec 2018 9:07pm |
AJ - the old box has to go back there's a surcharge on it so that's not an option (as there is with all suppliers I called). 2007 Vogue TDV8 with 255/55/20's fitted |
16th Dec 2018 9:18pm |
Graeme - if either a) the solenoid was faulty and partly energised for example, or b) incorrectly fitted, would that stop the selector shaft from turning? The solenoid is a pig to fit - has to be done energised - we ended up jury-rigging a 12v boost pack and some cabling to fit our old solenoid back to the original box. 2007 Vogue TDV8 with 255/55/20's fitted |
16th Dec 2018 9:34pm |
jonnyboy, I was assuming that the new box was faulty and would be going back for a refund hence my bearing suggestion. BMW i3 Electric Car
16th Dec 2018 9:39pm |
Hi AJ, what I want them to do is send me a not-faulty one and a shedload of cash to cover labour/fluids etc. But that latter part will no doubt not happen.
16th Dec 2018 9:42pm |
The transfer box splits down the middle seam so it’s easier to open to replace the duff bearings. If the spline for the hi low sensor is in a funny position it would seem that the box is stuck between the 2 ratios hence not engaged with either and effectively in neutral. Not that I recall there being an actual neutral position, which is probably why the cars toys have come out of the pram as it’s seeing something it’s not expecting.
16th Dec 2018 10:37pm |
I would be wanting to check that the fork operated by the solenoid moves freely between its 2 positions and when in the same position as the one in the old box then I would expect the motor shaft to move similarly to the old box.
16th Dec 2018 10:41pm |
Hi nmj
Absolutely will have a conversation with them but as I've already had significant issues re: delivery I need to be forearmed with knowledge before I pick the phone up! 2007 Vogue TDV8 with 255/55/20's fitted |
16th Dec 2018 10:42pm |
Good luck it sounds an awful situation. Hope you get sorted promptly BMW i3 Electric Car
17th Dec 2018 7:33am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
Have you contacted RRPhil for some assistance? |
17th Dec 2018 2:30pm |
