|  | Home > Technical (L405) > SDV8 Front Suspension Knocking - LTB00557v8 - Help Needed |
| Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369      | Further to my previous entry in this posting....
|  13th Mar 2018 11:00am |
| CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208    |
|  13th Mar 2018 10:53pm |
| ahbeddoe13 Member Since: 05 Mar 2018 Location: Cardiff Posts: 6      | I have a 2013 4.4 L405 and have a suspension knock over some....not all pot holes and rough roads. It sounds like an anti roll bar bush or drop link type noise, but I replaced those recently and it had no effect on curing the noise. I have spoken to a really good fitter (little experience on the L405 but used to be  LR Master Tech) and he is going to test the wear on all the bushes etc when he has the car next.
|  26th Jul 2018 6:25pm |
| Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100    | Just thought I’d add the latest news and keep this going as this must be a subject that still affects people.
|  18th Dec 2018 7:52am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Mine was cured lately by changing the front shocks ARB bushes and a valve block... All under warranty at 5yrs old   | ||
|  18th Dec 2018 9:52am |
| Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100    | Hi Craig and thanks for the reply.
|  18th Dec 2018 9:55am |
| 160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 461      | Interesting Craig - I have yet to check which valve block mine has but how did you get them to change the valve block etc on a car that old? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
|  18th Dec 2018 10:49am |
| 160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 461      | Second question Craig - what mileage has yours got? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
|  18th Dec 2018 10:50am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Car is under JLR used car warranty and has covered 79k... the repairs were only carried out 100 or so miles ago but have transformed the ride... hope that helps?
|  18th Dec 2018 1:05pm |
| 160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 461      | Thank you yes that does help - My car is also covered by the same warranty and similar(ish) mileage. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
|  18th Dec 2018 1:37pm |
| Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409      | Sad to say I need to add my 2014 to this ever-growing list of early cars knocking at the front.
|  19th Dec 2018 10:08am |
| Maffya Member Since: 28 Apr 2015 Location: Haddington Posts: 4    | I thought I would post an update since my last in November ‘17. The car went to Lloyd in Kelso after my last post, along with many print outs of posts on various forums pointing towards the same issues. They were very helpful, immediately confirming, when I showed them the video, that the lower control arms should not be moving as they clearly were. These were replaced, the remainder of the suspension and bushes etc (apparently) checked, alignment carried out and the car returned. The quality of ride was significantly improved, which you would expect from the new lower control arms alone. However very quickly it started to behave like before ie movement side to side, unstable across bumps and quite unpleasant. This was a few months after the lower control arms were replaced. Throughout the knocking / rumbling noise has remained. I have since had the wheels refurbished, which allowed me to change the tyres which although only part worn, they had worn unevenly with feathered edges etc, I think all linked to the various failed bushes over the last couple of years. I then revisited Lloyd of Kelso to check the alignment and to generally check the suspension again. The new tyres did improve the ride slightly, but I think only because they were new tyres and quieter rather than enything else. On a test drive with the workshop manager, he said that he had again updated all the software relating to suspension and he felt this had improved the ride. As always, on a test drive, the car was OK and it was hard to demonstrate the issues because (1) we only travel a short distance and (2) I am sure the technicians drive lots of cars but over short distances and without the benefit of living with a car day in day out, so I am not convinced they can pick up on the finer characteristics of the car. Nonetheless, I took the car away but it was back to normal ie unstable ride, harsh over bumps etc etc. I battled on, fed up with visiting the dealership, however after a drive from Scotland to Suffolk and back over this New Year, I had enough and contacted JLR Customer Services. The drive was not enjoyable, with the car crashing over bumps, moving about, unstable and even more exagertated, quite uncomfortably, in windy conditions. JLR have responded quickly and the car is off to Lloyd again on Tuesday. I have suggested they replace the anti roll bar system with valve, all associated bushes, air struts etc as this is clearly the fix that has worked for other customers. JLR were defensive of this and suggested we start with a test drive with the workshop manager. I suspect to be told ‘there is nothing we can find at fault and the car is as it should be’. I am close to ending my now long term relationship with JLR products if they do not at least change some parts in recognition of my concerns and the information I have given them about other customers similar experiences. My final point to add, which I have relayed to JLR and Lloyd, is that with either an empty trailer on or with a car full of passengers and luggage, the ride is great! Apologies for the ramble ....... | ||
|  4th Jan 2019 7:20pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Rather than move away to another vehicle if no warranty success with dealerships, you could have the front struts replaced at your cost, possibly by an independent at lower cost than a dealership, as the MY13/MY14 struts are renowned for causing your ride problems although not particularly the knocking.
|  4th Jan 2019 8:00pm |
| Maffya Member Since: 28 Apr 2015 Location: Haddington Posts: 4    | Thank you GraemeS. The suspension raises and lowers without any problems, as far as I am aware at least. I park every night with it lowered and it always goes down and stays down. I only mentioned front struts as others had mentioned that they had these replaced as part of the anti roll bar with valve renewal. I am concerned that if I have a faulty anti roll bar, it will have caused unnecessary strain on other parts. I wil though mention the struts to them on Tuesday and thank you for your suggestion. There is a very good Indy in Edinburgh! | ||
|  4th Jan 2019 8:18pm |
| Posting Rules
