Home > Technical (L405) > Erratic side step behaviour
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
L405 2014 AB SDV8.
Side steps have a mind of their own... sometimes they come out, some times they don't. Some times they come out on one side only.. very frustrating what you need them to climb in...especially what I have a pregnant misses, and a 94 year old grand mother to contend with.
No fault codes at all on the IID Tool.
Help very much appreciated Thumbs Up
Post #498986 18th Dec 2018 8:25am
there are a few plugs underneath so i would check thise first...
Post #498987 18th Dec 2018 8:29am
Charles89
Thank you.
I have unplugged them and WD40 them up and it's still the same unfortunately. Is there anything else I can check or do? It's very annoying. It happens in bouts, it can be totally fine for a whole week and then start playing up for 2 weeks... I'm stumped
Post #498989 18th Dec 2018 8:31am
does this happen after rain?....this maybe suggests water is still getting in somewhere ..or it could be an electronic gremlin..
Post #498994 18th Dec 2018 9:27am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Could be a module that is located against the transmission tunnel at fault, plugs lose? or the switch in the overhead consul these are plugs that are easy to check?
Post #498995 18th Dec 2018 9:37am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Mine behaved similarly until I lubricated the moving parts, been ok since - suspect the antitrap was kicking in on occasion.
Post #498999 18th Dec 2018 10:11am
The OP has a 405 so the module is in the right rear compartment behind the seat bolster... And the switch is in front of the drivers right knee sir... Thumbs Up
I would try a battery reset first, then check the connections are all good, then replace the switch (as its the cheapest) then the module (remembering to buy an age appropriate one as the can-bus changed on later years)
Post #499002 18th Dec 2018 10:40am
CJB1000
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
There is a software update for this issue available from the dealer network. However, the deployable side steps have an “intelligent “ feature, that kicks in if the vehicle detects it is being driven over rough terrain or off road. In this scenario the steps will not deploy until back “on road”.
Post #499008 18th Dec 2018 11:26am
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I had this exact fault with erratic side step behaviour - the dealer (who I have no faith in at all after they damaged my car whilst it was in recently for a reversing camera issue) told me they had updated some software.
In truth, I didn't know if I believed them because they were so awful to deal with but this does lend credence to the story that there is a software update available.
I get the car back later today so will let you know if the behaviour of the steps has improved 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #499009 18th Dec 2018 11:46am
They have an anti trap feature and the steps predominantly work off the terrain response system hence switches off in mud n ruts etc etc... not heard of a software update but I will check later when I get back 👍
Post #499023 18th Dec 2018 2:14pm
Charles89
Thank you all for the input. Interestingly I have a static fault in the terrain module, something along the lines of quqesent (if that's how you say it) voltage issue. When I questioned the dealer recently they said "it's perfectly normal to have this fault in the terrain response unit" however, if I turn the terrain response off, by clicking the knob so it sticks out, I have no difference (except the junction full lock shudder goes away) in the behaviour of the steps.
How might I lubricate the mechanism to prevent the anti trap from kicking in?
Post #499043 18th Dec 2018 6:21pm
Charles89
I will eagerly await your update. I have also lost faith in the dealer... Thumbs Up
Post #499044 18th Dec 2018 6:25pm
JCW
I used a spray on white grease with an extension tube attached to the nozzle (like you get with a can of WD40) to get it directly into all the pivot points, I operated the steps multiple times by opening / closing the door and this seemed to free up the movement, whereas they used to start to extend / retract then stop, one side would be out whilst the other in etc, but now all seems ok for me.
Post #499046 18th Dec 2018 6:35pm
As JCW says...plus just be prepared to manually "help" the step out and back the first couple of times if its sticking. Also important to do the motor spindle as well as the step pivots (that was actually the critical area for mine second time of sticking)...admittedly on the L322. Mike - MPx
Post #499065 18th Dec 2018 8:59pm
I lubricate all my customers steps (using white grease) at service point...
I then lock & unlock the car a few times to work them... Thumbs Up
Post #499078 18th Dec 2018 10:40pm
