![]() | Home > Technical (L405) > Fuel operated heater but no park heater |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I would suggest not. It will use the FBH to help the engine warm up whilst driving but you dont have the facility to run the FBH without the engine running to heat the car up.. BMW i3 Electric Car
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
This is the one thing I miss from my Discoveries, unfortunately if the remote part of the system wasn't specced when it was new it would appear you can't add it at a later date |
Here's the thread with the error it kicks up
I don't know about Land Rover but VW when they don't fit parking heater they omit the water pump too so even though the FBH is there to aid warm up you still cant run it whilst the engine isn't running hence my guess above. Do Land Rover fit the water pump under these circumstances? BMW i3 Electric Car
As far as I know if it is not specced when new you don't get the water pump but you can set the FBH to run for 20 minutes before you are due to go out via the timed climate and it will heat the cabin up but it wont heat the engine. My car can be totally covered in frost/ice in the morning but after the fbh has run for 20 minutes (without the engine running) the windows will be defrosted and the cabin will be warm. |
How does it heat the cabin without water flowing through the heater matrix? BMW i3 Electric Car
I really don't know that's above my knowledge but it does warm the car up on frosty mornings. Cheers Ian
azaroth Member Since: 14 Feb 2019 Location: BE Posts: 3 ![]() ![]() ![]() |
Great work, folks. I really appreciate reading the forum and finding my way through to getting the job done. Now happy with the option of stepping into a warm car in the morning, especially when it's freezing like now. Done with it on my 2013 Vogue with the IIDTool BT. |
