![]() | Home > Technical (L322) > locked out |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Battery in key fob ? .
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3858 ![]() ![]() ![]() |
Tip of the day... Duracell batteries work best in key fobs.
Nice but dim tim Member Since: 28 Feb 2018 Location: Fareham Posts: 7 ![]() ![]() ![]() |
Key fob battery changed twice |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
First post and you want to know how to get into a locked FFRR, hmmmmmmm. |
Without a key or a lock that won't work, it is nigh on impossible without causing some serious damage to a door or breaking glass. ( I know I tried when I locked my keys in the car) Had to buy a new key (my lock worked OK)
Cheers joe I think you may be right about smashing the drivers window |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7971 ![]() ![]() ![]() |
Take it you have tried holding the unlock button down on the fob to see if all the windows come down? You get the red light on the key when you press the button?
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
How can you tell battery is fully charged ?Mine did that when I left side lights on all night had to jack car up and connect battery pack to starter motor connection then she unlocked no prob .My key would also not unlock drivers door at the time so I fixed it so I would not get caught again good luck |
Cheers mjdronfield and rik, just had a go at press and hold unlock button, no joy |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
How did you charge the battery via the towing connection as that should be connected to an ECU
^ There are two direct feeds from the battery, albeit through fuses, to the rear tow sockets which can be used to charge the battery. These two don't go through an ecu. |
Every day is a school day |
GraemeJudge Member Since: 10 Feb 2018 Location: Fareham Posts: 54 ![]() ![]() |
I have also put an Anderson connector to the jump start point and mounted it on the front bumper on with a cover allowing me to put a multi meter across and check the voltage of the battery and make it nice and easy to jump start if needed,
The forum offers a made up CTek charger connector to the trailer socket.... (see Shop)
