Home > Technical (L322) > Range Rover L322 front parking sensors
ricky25
United Kingdom 2003 Range Rover Vogue Td6 Rimini Red
I have a puzzling problem with my front parking sensors on my 2003 RR L322 Vogue. The rear sensors work fine (either by engaging reverse or pressing the PDC dashboard switch.) They also automatically switch off once I’m driving. However, the front 4 sensors don't work at all. Any suggestions please? I’m wondering - could it be the front sounder?
Post #499334 21st Dec 2018 3:55pm
The front and rear are linked so if just one sensor fails the whole system shuts down... Do you have a way of checking through diagnostics sir? As it will show you whats working and whats not through live data... Thumbs Up
Post #499335 21st Dec 2018 4:02pm
alistairh
The system shuts down if ones faulty from
Memory. Best bets getting it on diagnostics and you can watch each sensor via live data. Saves so much messing around and guess work.. an iid tools perfect for this
Post #499336 21st Dec 2018 4:02pm
Great minds Alistair Bow down Thumbs Up
Post #499338 21st Dec 2018 4:09pm
ricky25
Hi guys and thanks for the prompt response. No - I don't have any diagnostic testing kit available. What's puzzling me however, is that the rear sensors work perfectly and the front, not at all.
Post #499339 21st Dec 2018 4:15pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Im far from an expert and excuse me if this is an obvious question, but did you turn on the front parking sensors ?? The rears come in if you select reverse but the fronts dont work unless activated. My mercs front ones werw on permanently as were the rears so when i got my first L322 i thought the fronts didnt work until i realised they have to be manually turned on. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #499347 21st Dec 2018 5:02pm
ricky25
Yes - I've tried switching the front sensors on manually but they still didn't work.
Post #499349 21st Dec 2018 5:18pm
dolph34
Thumbs Up just going on my own experience sir. if the front and back are linked as others have stated then its strange the backs work. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #499351 21st Dec 2018 5:29pm
alistairh
@camtech Craig.. haha I agree sir. Both of us replied same time 😂
Post #499361 21st Dec 2018 6:51pm
Norm
Canada 2008 Range Rover HSE 4.4 V8 Alaska White
If it's a sensor that's failed you can pinpoint which one by turning them on and then putting your ear up aginst each one in turn. You should be able to hear them clicking if working. Check the wiring close to the sensors it can cause a sensor to not work.
Post #499363 21st Dec 2018 6:58pm
