Home > Technical (L322) > vacuum oil change td6
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
hi folks-will vacuum method suit td6 L322...i am a fan of this method but on my 530d[m57m] it leaves a few litres...anybody>?
Post #499369 21st Dec 2018 7:29pm
Couldn't see a need for it when removing the sump plug on a td6 is so easy, you hardly need to reach under the front to access it. I must admit I prefer to be sure all the old oil is out. Thumbs Up
Post #499374 21st Dec 2018 8:24pm
tony66
oil
i did previous td6 oil change years ago but cant remember if will allow it via suction for full evacuation
some cars evos,audi a4 but to name a couple you get more oil out via suction
i am a convert to it wherever possible tbh
Post #499384 21st Dec 2018 9:28pm
As per NDFI, just warm it up and undo the sump plug and allow to drain for an hour .
Post #499400 22nd Dec 2018 12:48am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Like others, I could not see the point but having used a vacuum evacuator on another car and reading that dealers regularly do the same I gave it a go on my TD6. Straight into my garage from a 20min drive, bonnet up, tube in dipstick tube and out the old oil came. Cup of tea, changed the oil filter by this time no more oil coming out. Just to check I removed the sump plug and just a few drips. My evacuator is 9 ltrs and it was very close to full so I am confident it got all the oil out. I have since done it 2 more times, once warm and the other hot. It needs to be hot or it takes forever.
I like it, no mess, no bending over or rolling on the floor dragging a bowl of hot oil which I always manage to spill. Even If I do remove the sump plug in the future I will always use the pump 1st. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #499411 22nd Dec 2018 12:12pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
That makes so much sense, pump the oil out from the top and then remove the sump plug to get the last of the oil out.
Does anyone else do it that way?
When I've taken sump plugs out if full of oil it usually goes all over me and the floor.
Post #499412 22nd Dec 2018 12:29pm
tony66
thanks folk-it will be getting sooked oot...nice and clean
Post #499413 22nd Dec 2018 12:33pm
tony66
oil
vacuumed it out today-painless almost 9 litres[takes 8.75 allegedly]
mahle filter
reset light -done for now
Post #499425 22nd Dec 2018 3:12pm
Springer
United Kingdom 2003 Range Rover Vogue Td6 Galway Green
Hi do you have a picture or a link to the pump that you used ?
Thanks
Post #499478 23rd Dec 2018 10:49am
tony66
vacuum
i dont have a pic-but its the common sealey item,there are 6.5 litre and a larger size[10 i think]
i have the smaller 6.5 litre so have to disconnect and empty during a bigger vehicles oil change
the first looks good value
second is what i have
https://www.ebay.co.uk/itm/9L-Waste-Oil-Wa...1438.l2649
https://www.ebay.co.uk/itm/Sealey-TP69-Vac...rk:16:pf:0
Post #499488 23rd Dec 2018 11:48am
wayneg
The ebay link to the 9ltr one looks exactly like mine. For the price its a good bit of kit. I have had it full of old oil and transported it upright with no spills. To empty pull the bung from the top where the vac lines enter and you have a well-shaped pouring spout. The only thing which you might want to pay more for is the ability to pump the oil out via the tube, this I have seen on more expensive types. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #499504 23rd Dec 2018 1:46pm
tony66
oil
for anybody doing this make sure you have a couple 5 litre or similar old oil containers-put old oil in them and take to tip/give to somebody with a waste oil heater etc-you only need one if changing oil in a small car
Post #499512 23rd Dec 2018 3:57pm
nino_nino
a
If you are handy type, make one for yourself for next to nothing. Very Happy
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #499515 23rd Dec 2018 4:26pm
