![]() | Home > Maintenance & Mods (L405) > Full size spare boot size? |
| ABAB Member Since: 02 Feb 2017 Location: GB Posts: 288
Triarii - not sure if you did the swap over yourself. If so, you’ll have no doubt discovered one of the features of the full-sized spare and that’s the immense weight of it. I thought I could ignore the special “winch” that helps get the wheel out of the boot well but I couldn’t budge the thing without this. 2016 SDV8 AB |
| Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177
The part number for the winch is LR085460, I think the list price is about £80 but I managed to get a brand new one from Ebay for £25 Cheers Ian
| Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 193
When I first changed the wheel the guys in the garage did the heavy lifting. I now have one of the winch thingies. |
| nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233
Quick questions to the team - does a full size spare have it's own TPMS device fitted? I'm assuming it must.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871
this is from the 2010-2012 WM and i assume it will be the same for your year,
That's brilliant - thanks Stan! |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Mine has a 23" full size spare and the floor is still flat |
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
What width of tyres are those Craig ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
It came with 21's when i bought it, so 275 width. It then had multiple sets of 22's with 275's 285's & 295's and the spares all fitted under the boot floor. It now has 285's on the 23's... |
Well, (excuse the pun) my new full size spare fits perfectly - very pleased with the purchase. Cost me about £160 more than specifying it from new, but there you go, lesson learned.
Your ratchet set up would appear to be a much better solution than the Land Rover one |
