Home > Technical (L322) > Articulation validity fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
you havnt by chance put the height sensors in back to front?? |
24th Dec 2018 10:05am |
steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56 |
Don't think so as both plugs are facing upward, also if I turned one over the plug looks like it would foul on the chassis |
24th Dec 2018 10:33am |
i did a forum search and that was a possible cause the another was broken wiring.. |
24th Dec 2018 10:37am |
I've searched also and can't come up with a definitive answer |
24th Dec 2018 10:40am |
Just read these values from icarsoft 930, front right voltage 2.85v height 0.038, front left voltage 41.86v, height 0.053
26th Dec 2018 4:32pm |
petebowling Member Since: 17 Jul 2018 Location: Thetford Posts: 20 |
I have the same problem replaced the two rear sensors and now will raise front fine but the rear gos up but not level
27th Dec 2018 7:27pm |
You can get the plugs with wire tails from this site, look on shop on the home page that's where I got mine listed under connectors and adapters |
28th Dec 2018 11:14am |
I had this on my l322 you could clear fault then it would be back a mile down the road.
7th Feb 2019 7:34am |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 336 |
My old range rover had a few height issues and I ended up having 4 new sensors although only 2 were dead, I was told that they work within a set tolerence of one and other, so if they all wear at the same rate and voltages shift etc they stay within that tolereance, introduce a brand new sensor and it then operates outside of the tolereance and the car doesn't like it.
7th Feb 2019 10:13am |
staffs964 Member Since: 21 May 2016 Location: Ontario, Canada. Posts: 10 |
My car is practically off-road most of the time or at least that’s the state of the roads here (BVI)
14th Jun 2019 7:41pm |
