![]() | Home > Technical (L322) > I may need a starter motor ? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
sounds like the problem i had , new starter and everything was ok.. |
| brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275
I thought so Stan to, now to source one. |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1417
Battery stood for two months on the car as well??
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
My 2012 WM was the same, battery fine, system powered up fine, but starter sometimes had to be pressed several times to get an reaction. At first it was silent, suggesting that the button/switch was the problem, but then there was a little click, suggesting the starter motor. The motor was tested and thought to be the problem. It was replaced and the problem never came back. They seem a known weakness, mine was about 55,000 miles at the time. Only Range Rovers since 1988 |
Spot on CS, the exact symptoms and mileage just turned 55,000 too. |
