Home > Group Buys > Reversing LED bulb (CanBus)
Sign Up
(33) No spaces left.
User Registered Confirmed
Redbaron23rd Nov 2018 5:26pmRedbaron is confirmed
MadL3221st Dec 2018 9:58pmMadL322 is confirmed
Stormin2nd Dec 2018 5:35pmStormin is confirmed
Shewy2nd Dec 2018 7:46pmShewy is confirmed
phil674th Dec 2018 10:29pmphil67 is confirmed
JST5th Dec 2018 9:13pmJST is confirmed
horse868th Dec 2018 3:50amhorse86 is confirmed
Gyre88th Dec 2018 8:19pmGyre8 is confirmed
kds28th Dec 2018 9:57pmkds2 is confirmed
nearlee9th Dec 2018 7:37pmnearlee is confirmed
Parallel10th Dec 2018 11:31amParallel is confirmed
procee10th Dec 2018 12:25pmprocee is confirmed
rover610th Dec 2018 9:18pmrover6 is confirmed
paulbrown2211th Dec 2018 12:44pmpaulbrown22 is confirmed
vaz17th Dec 2018 10:01pmvaz is confirmed
Triumph7220th Dec 2018 1:57amTriumph72 is confirmed
Norm20th Dec 2018 6:58pmNorm is confirmed
Scottyav23rd Dec 2018 7:06pmScottyav is confirmed
dantesdango1st Jan 2019 10:15pmdantesdango is confirmed
DavidS2nd Jan 2019 1:26pmDavidS is confirmed
jimlad712nd Jan 2019 3:35pmjimlad71 is confirmed
Ticketyboo Too3rd Jan 2019 5:17pmTicketyboo Too is confirmed
Harlin4th Jan 2019 8:04pmHarlin is confirmed
Jpboost6th Jan 2019 7:11pmJpboost is confirmed
RiX13th Jan 2019 4:38pmRiX is confirmed
paul7025th Jan 2019 9:16ampaul70 is confirmed
Clive28th Jan 2019 12:15amClive is confirmed
jonlewis28th Jan 2019 3:11pmjonlewis is confirmed
chief647th Feb 2019 8:58pmchief64 is confirmed
Dazzab19728th Feb 2019 3:54pmDazzab1972 is confirmed
BusterMurphy23rd Feb 2019 1:45pmBusterMurphy is confirmed
Cooper12752nd Mar 2019 2:24pmCooper1275 is confirmed
CY8818th Mar 2019 4:20pmCY88 is confirmed
Page 10 of 15 <123 ... 91011 ... 131415>
pumpkinboy1991
Scotland 2002 Range Rover HSE 4.4 V8 Oslo Blue
Are there any bulbs left? I would be keen to purchase a set please! Would help alot with hitching up which I do fairly regularly.
Thanks, Ollie
Post #499607 24th Dec 2018 8:33pm
Tight777
All done, paid for 2 sets, Merry Xmas.
Post #499638 25th Dec 2018 11:14am
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Happy Christmas all, just fitted my bulbs, Christmas present to the thing. !! Camera doesn't pick up the difference but it is definitely discernible with the naked eye. Happy Holidays all Thumbs Up
Post #499646 25th Dec 2018 3:10pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
I've had to change back to the standard bulbs as these LED bulbs caused the AV screen to flash on/off, mucho beeping and an occasional totally black screen when using reverse.
Some kind of Canbus error perhaps?
Post #499868 28th Dec 2018 1:42pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
How very odd! no-one else has reported such behaviour, you do occassionally get the LED's to twinkle at start up, but nothing that effects the camera.
Is your camera factory fitted? just wondering if it's an aftermarket that's powered by the reversing bulbs circuit? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #499873 28th Dec 2018 2:22pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
That would be my guess too Bushy.
Having upgraded my camera I know how crucial it is to have a "clean" live feed. It doesnt tolerate interference at all.
I would check the camera live feed 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #499901 28th Dec 2018 7:03pm
Gyre8
Reversing camera looks to be standard issue factory fitted to me - if it has been changed out, it's certainly not anything special.
Ref: Twinklies; do you mean the dashboard lights? If so, no twinkling that I've noticed.
It just seems a bit of a coincidence that before I changed over to the new LED bulbs the reversing camera was working OK, and then it started playing up after I put the new bulbs in.
Anyway, have put the old bulbs back in and will see how it goes.
Post #499910 28th Dec 2018 8:43pm
Bushy30
No, not the dash, when the ccts are tested on startup the LEDs flash Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #499913 28th Dec 2018 8:45pm
Grofus
It won't be a coincidence. The Leds, by their nature will produce interference. But, the camera can only be affected if it has a wired link somehow.
The obvious one being it live feed wired into the reversing light circuit. Even a shared ground would do it. I went through all that with my camera upgrade. Check how the camera is wired in chap. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #499916 28th Dec 2018 9:35pm
Gyre8
OK, Thank you. Will check.
Post #499927 28th Dec 2018 10:18pm
Gyre8
Right, Reversing Camera does not work at all now, just a black screen - even with the old bulbs in. Perhaps I disturbed some wiring when changing the bulbs (you know when you wish you'd never bothered)? Although both reversing lights do work, the camera doesn't.
I've bought a new halogen H6W bulb to try that out. It works normally, but does not resolve the camera black screen issue. I notice the old bulbs had asymmetric bayonet pin placements, but the new ones are diametrically opposed to each other. I assume this is not an issue as both bulbs work.
Anyway, it is what it is. I'm not an auto electrician, so I've no idea what I'm looking for (apart from the obvious broken wire, etc).
Next step is to find a local auto electrician to find and resolve the fault.
Post #499985 29th Dec 2018 1:31pm
Grofus
You need start a new thread for the problem. I will help where I can 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #499997 29th Dec 2018 3:26pm
Bushy30
Agreed Grofus, new thread, preferably with piccies or wiring which will mean a lower tailgate strip down Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #500001 29th Dec 2018 4:13pm
dantesdango
United States 2003 Range Rover HSE 4.4 V8 Giverny Green
Happy New Year all.... Bushy, can you PM me the cost to ship 2 sets to the US please? Thanks.
Post #500277 1st Jan 2019 10:24pm
Bushy30
Right folks I have one pair left which should go to Scotty -- I'll PM you!
Dantesdango -- can you PM me the address please.
I'll also ask the nice folk in China about another order as soon as we have ten folk signed up again.
Thanks
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #500323 2nd Jan 2019 1:38pm
