Home > Maintenance & Mods (L322) > Adjusting upper tailgate position
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Just noticed on my 2003 L322 the upper tailgate, when closed, has a slightly larger gap down the left hand side (where it meets the rear pillar) than on the right.
I know (well, I’ve read somewhere) you can adjust the positions of the latches, but would they be enough to ‘pull’ the tailgate closed more aligned? Or is there any other adjustment?
Hope that made some sense....
Post #497789 6th Dec 2018 7:23pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Did you get anywhere with this? Got exactly the same issue, left side doesn't seem to close quite as well as the right, and doesn't seem flush. As I close the upper tailgate, the noise from that side is just a bit flimsy, it's definitely not catching as it should. Fairly sure this is causing ingress issues in this weather
Post #499293 21st Dec 2018 12:40am
gj88
bump
Post #499541 23rd Dec 2018 9:26pm
mpirie
Wouldn't the workshop manual give you a guide under replacing the tailgate?
I'd assume there would be some gap information and an indication of where the adjustment (if any) was.
Mike
Post #499550 24th Dec 2018 9:58am
gj88
I looked before asking, nothing there I could find
Post #499555 24th Dec 2018 10:16am
mrblonde
Sorry gj88 I havent had a chance yet, build up to christmas and extra shifts in work means havent had a free day yet. Plus MrsBlonde keeps 'borrowing' the RR and leaving me her car... Censored
Its on my list of things to look into in the New Year
Post #500048 30th Dec 2018 8:42am
