![]() | Home > Technical (L322) > Poor Charging |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766 ![]() ![]() ![]() |
HNY!
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I’m no mechanic either but I would say you are along the right lines if the alternator isn’t putting out enough charge, should be 14.2 v +, but I think I have read somewhere that some alternator output is controlled via an ECU based on demand. One way I tested an alternator recently to check for low output was to take the positive connection directly from the alternator or the battery if not accessible and the earth from the alternator casing to try and rule out a bad earth - whether that is ok on a Range Rover being a fussy little princess I’m not sure. |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
You have a drain somewhere, which may only be present when the alternator is charging. Should see 14.2v
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
If you have a new alternator and new battery and still only get a battery voltage around 12.4 V it suggests to me you have a poor connection somewhere on the charge circuit. After a run of 80 miles I would initially expect a battery voltage of about 12.8V. If you have a battery voltage of 12.4V and go for a run I would expect a charge voltage of about 14.8V for a period slowly reducing to about 14.4V or so as the battery charges.
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 92 ![]() ![]() ![]() |
I believe the later emissions controlled vehicles (5 & 6) only charge to 80% battery capacity to allow for regenerative charging capacity.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
+1 for Arbuckles description. My 2011 VSE can do a 400 kilometre trip and if i open the doors 5-10 times is will say low battery. I can drive 30 kilometres and watch dvds for 1/2 hour with no issue. I used my IID TOOL to moniter the live values for battery charging and battery level percentages wise. If the low battery warning comes up , the live values ahow 77% ish battery and charging is at 14.8. If no low battery warning then IID tool shows 82% and charging at 12.8 ish unless decelerating when it will increase to 13.8ish. 2015 4.4 AB
Thanks Dolph34 for the figures.
No problem Arbuckle , i was all for changing the altenator until i saw the live values and other members shared their experiances. I would imagine a larger battery would help. I have a 105 ampere, 950 cca currently ( sic) may look for more powerful one next time. 2015 4.4 AB
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
If it hadn't been for mileage i would have stuck with my 3.6 Grofus. Fantastic machine. The charging ' issue ' on later models is a bit bizzare. Even with the low battery warning the RR never fails to start or even turns over slower, i think Arbuckles description nailed it. 2015 4.4 AB
Maybe the solution is to fit an auxiliary battery.
Infiltrator Member Since: 26 Aug 2018 Location: Wiltshire Posts: 13 ![]() ![]() ![]() |
Thanks for all the replies. I've been driving LR's for the last twenty odd years, and the thing I love is that there is always help out there.
Hmmm, does look that way, and yet, it just doesn't feel quite right, if you know what I mean. No, wasn't aware that I had to tell the beast. Presume that is done through a Nanocom or Hawkeye? I have an Icarsoft LRii reader, not sure if that will do it or not. |
I'll be checking this weekend. Thank you. |
