Home > Maintenance & Mods (L322) > seized reversing light fixing screw broken lense fix
Gsxr1250dave
Thanks to bushy for the group buy on the reversing bulbs I can like every one else see behind my ffrr. However when I went to fit the bulbs like a few others the screw fixing the lenses is seized solid, when I went to undo it the plastic fixing on the lenses cracked and fell apart. I decided to leave it until I could have a proper look at a solution.
Well it was simple enuff I didn't buy new lenses for £80 a pair neither did I drill out the old screw infact leaving it in is the solution once I fitted and tested the bulbs worked I refitted the lenses and got out my trusty glue gun, give it a good blast of hot melt under, around and over the screw filling the void up in the lenses and let it set.
Job done hope it helps others,
picture supplied I should have taken a few when doing it but doh....
Post #500283 2nd Jan 2019 12:07am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #500302 2nd Jan 2019 10:44am
and next time ? Twisted Evil .
Post #500319 2nd Jan 2019 1:00pm
Gsxr1250dave
Next time ??? Hopefully the led bulbs last a long long time even if I get a failure the hot glue can be picked out pretty easily
Post #500332 2nd Jan 2019 3:10pm
actually thats not a bad idea..a bit of hot glue covering that screw will protect it somewhat....
Post #500333 2nd Jan 2019 3:12pm
Different (better?) fitting on later models. On the early ones was a threaded screw into a metal pressfit, on the later ones was a self tapping screw into a plastic pressfit. YMMV .
Post #500342 2nd Jan 2019 4:06pm
Gsxr1250dave
Mines the early one with a metal press fit sooooo the screw has pretty much rusted its self in there never to come out again with out major surgery
Post #500363 2nd Jan 2019 6:59pm
Yep, been there Thumbs Up .
Post #500366 2nd Jan 2019 7:20pm
