Home > General > Buying advice 4.4 TDV8
jackie-o
Netherlands
Hi,
I found a 2012 4.4 TDV8 Autobiography in Holland that I thought I´d ask your collective advice on;
It was originally sold in Germany where it has had all services done by the local LR dealer, by the book.
The car was imported by a dealer to Holland in September 2016, at approx 43.000 miles.
The Dutch guy who bought it apparently changed his mind and the car is offered for sale again through the same dealer that imported it.
It is now at 51.300 miles and has been standing in a showroom for well over a year.
The DPF Filter was changed by a Dutch LR shop in 2017. Explanation being that the car had been driven a lot of short distances. No service has been done since February 2016 at 4.000 miles (LR in Germany).
Nothing except for the DPF filter has been changed outside of normal maintenance.
The car looks fantastic on photos and has literally every option available. The asking price is 39.000 euro which is about 5.000 euro too high in my opinion.
Given the history of the DPF, no service for 3 years (1.100 miles) and that its been standing still for over a year; would you buy it?
If so, what are things to look out for and what kind of questions would you be asking the dealer?
Very grateful for any pointers!
Thanks!
Post #500836 7th Jan 2019 11:58am
Baltic Blue
You are unlikely to find one with lower mileage.
I would say, given a new full service, including reports on the brake discs and pads (which are probably near the end of their life), it should be good for many more thousands of miles.
This link highlights common problems with 4.4tdv8’s.
Check the 4 short manifold hoses and also for any signs of oil leaks around the oil cooler.
https://www.fullfatrr.com/forum/topic44115.html
Post #500843 7th Jan 2019 12:21pm
jackie-o
Netherlands
Thanks for the reply Baltic Blue and for the link. There´s really an incredible amount of info here.
Do you know the approx cost of fixing pads and discs at an LR shop?
I need as much ammunition as possible for getting the price down if I decide to buy...
thanks!
Jonas
Post #500851 7th Jan 2019 12:51pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Its more like 10000 euros over priced, full brake overhaul £1500 plus it would need a very thorough service indeed.
Post #500857 7th Jan 2019 1:23pm
jackie-o
Netherlands
Thanks Brian!
No concerns over the DPF filter changed so soon or any possible knock-on problems this could have caused?
Post #500884 7th Jan 2019 9:06pm
GGDR
My guess was that it would have been replaced under warranty.
The car may be prone to DPF filling up, but this all really depends on use.
One 20 minute motorway journey a week (or every two weeks) will keep the DPF in good condition.
What you really need to know is:
- Has the alternator been replaced (these can go 70-80k miles)
- Same for starter motor
- Same for oil cooler or oil cooler seals
- Has the turbo drain modification been done.
- Is this error code present: P040D-00 (2F) Exhaust Gas Recirculation Temperature Sensor A - circuit high
These can also be points of negotiation for you.
. Cheers, Greg
Post #500885 7th Jan 2019 9:18pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Priced about the same as over here in the Emerald Isle 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #500886 7th Jan 2019 9:35pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
A set of new tyres will be on the shopping list after a year of showroom. 20 inch x 5 are well in the 1500€ rangenfitted if proper rubber is choosen.
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #500893 7th Jan 2019 10:42pm
gg2201
Any vehicle stood up for long periods of time can create problems but if it's been in a warm showroom then it's probably not as bad. Things like the battery will be knackered if they haven't disconnected it or had a conditioner on it. The tyres may have developed flat spots too by being stood up so long depends on the showroom floor. Things like ceramic tiles are hard and you'll notice flat spots when you take the car for a drive.
Aside from that check everything electrical heated front seats fail, look for rust on rear arches and tailgate. Our AB doesn't have the turbo drain mod but doesn't smoke as it is driven properly everyday we do at least 50+miles in it with mixed driving so it's never been an issue along with the DPF and ours has double the mileage of this FFRR. 2011 4.4 TDV8 Autobiography
Post #500905 8th Jan 2019 9:42am
Foz01
How much cheaper is it to a comparable car?
Post #500967 8th Jan 2019 10:30pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Way overpriced. No more than 30k with an extended warranty as the turbos need clean oil or they wear faster. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #500976 8th Jan 2019 11:38pm
jackie-o
Netherlands
Thanks again for all input!
General asking price for this kind of milage, there aren't many, is around 35.000 euro for LHD cars. So this one is 5k too expensive to begin with.
Ideally, like Grofus wrote, I´d pay under 30.000 euro.
Its for sale by a private seller through the dealer so anything I can use to get the price down is great to have.
So far; service, brakes, tyres, all fluids, alternator, starter motor, which should easily amount to 5.000 euro.
If you can think of more things that usually fails around this milage or that possibly should have been changed already then please post!
Thanks!
Post #500999 9th Jan 2019 1:53pm
Foz01
I offered £13,000 under what a local dealer wanted for a TDV8 yesterday, they declined but i suspect they now realise the true value of the car they are trying to sell.
Old expression, if you don’t as you don’t get, so you never know.
Be prepared to walk away is the best advice!
Post #501003 9th Jan 2019 2:25pm
socialrover
"I offered £13,000 under what a local dealer wanted for a TDV8 yesterday, they declined but i suspect they now realise the true value of the car they are trying to sell. "
Wow ...how much was the car on sale for Foz01 ?
Post #501033 9th Jan 2019 8:02pm
Foz01
£65k, it was a 2015 4.4 AB, non franchise dealer, low miles but 10 miles up the road of the franchise dealer has a similar car with the 2yr LR warranty for 55k.
Post #501034 9th Jan 2019 8:10pm
