Home > Maintenance & Mods (L322) > Front disc brakes getting hot
JT
England 2006 Range Rover Vogue 4.4 V8 Tonga Green
Hi. Thought I had the dreaded front left brake caliper problem, so changed this over Xmas. The disc is still getting hot ( more so than the front right)but not boiling, Any helpful suggestion of possible problems would be appreciated.
many thanks John. my FF is a 2006, AJ 4.4 V8 petrol
Post #501154 10th Jan 2019 8:23pm
m@ttsFF
Brake hoses can collapse internally preventing fluid return so symptoms are similar to a sticking caliper 4.2 SC
Post #501156 10th Jan 2019 8:49pm
JT
thanks for suggestion. Had thought of this but assumed because they were replaced under recall in June 2015 they wouldn't have caused a problem but will replace just in case.
Post #501189 11th Jan 2019 9:54am
TomCobbly
You may have moisture in your brake fluid at the caliper which can cause this. You could just try bleeding some fluid out and seeing if it is clean. 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #501222 11th Jan 2019 2:49pm
JT
I did bleed the system when changing the caliper but maybe not enough. It will get a full change when I replace the hose. cheers JT
Post #501613 15th Jan 2019 9:51am
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
