![]() | Home > Technical (L322) > FBH isolates motor coolant from the FBH and cabin coolant? |
| kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 229
With yours being a v8 petrol have you even got the FBH ? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
i thought it did both...loads of info in the wiki.. |
| drakes Member Since: 26 Jan 2009 Location: Consett Posts: 375
I have a Defender with the same heater in but no diverter valve so it heats both the engine and vehicle interior so there is nothing in the heater to stop you removing or disabling the diverter. I think in the handbook it says something about heating the engine rather than the interior if it is below -20 so I wonder if that temp cold be changed. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
As I read it, the FBH operates in parked heating mode to only heat the interior, thus the changover valve sets itself so the coolant goes to the heater matrix only, circulated via a pump in the FBH. Thus not heating the engine.
| kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28
Yes 100% I have. Have repared the damn fbh control circuit and replaced the burner. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Afaik
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
D3;s without park heat - FBH heats the coolant only and quickly. I use this every day and the engine temp is displayed on dash at start up so happy engine starts every time and immediate warm air shortly after start up. |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
IIRC, diesels need the FBH as it takes so long to get warm so are fitted as standard (although many don’t have park heat option)
Totally awesome car. I would like to find these same rims for the winter tyres too, but unfortunately these are quite scarce here in Finland.
| kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386
I recall reading somewhere that when the temperature drops below a certain value (can't recall what exactly, I'm afraid, but it was quite cold), that the system changes focus and warms the engine coolant instead of the heater circuit. 2010 4.4 TDV8 Vogue SE |
| All times are GMT |
