![]() | Home > In Car Electronics (L322) > Reversing Camera Upgrade |
| Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714
Clemenz - Hi !
| clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183
I know, you have to source the right camera (check), get the parts for power connection (check) and to get the right video cable (pending but found). The benefit will be that you do not need to break your existing camera. i want to have an interchangeable camera. i can post some more details later at home (pictures, parts, etc.) |
Aaaagh - OK.
Ok, lets start with the information.
Camera:
And now is the part where i get stucked. I need someone with CAD skills who can prepare and repaire the scan.
Next Milestone reached: Camera reconstructed in CAD. Next --> Printing
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Fantastic solution!
First print from 3D home printer, next step, sanding and painting. Then somehow move the electric into the plastic dummy!
| Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240
Cool. Will follow this with interest |
| Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233
I am in the process of replacing the LR reversing camera on my FF. Found this on the bay. Item number eBay Item No. 142942635174. If you remove the existing camera components from the housing this aftermarket camera is a snug direct fit into the original space. Obviously you need take it out of the rubber housing it comes in. Sorting the wiring out tomorrow ( hopefully). |
Thank you for that link.
| littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 328
I saw an article for a reversing camera that doesnt need wiring, it works off the bluetooth function on your phone.
| Busterbulldog Member Since: 23 Oct 2015 Location: Caerphilly Posts: 7
I bought a 2007 rangie last week with a non working camera, i popped the camera out, the fault was on the 4 pin connector inside the camera housing. I dremelled the connector off and soldered the 4 wires directly and all working fine. Quite an easy repair. |
