Home > Technical (L322) > Suspension issue
nighttimer
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Suspension issue
Hi everyone,
Newbie here with suspension issue.
Have a fault registering on the diagnostics for my car, suspension issue C1130 Air Spring Air Supply
Can it be pin pointed more anyone know that code?
Warnings on my dash are suspension fault comes up says 15 miles into driving.
Then at some point in time suspension fault max 30 mph
All bags compress and it goes down to the bump stops
Have to pull the car over and restart it said vehicle raising slowly
This doesn’t always happen but when it does it’s dreadful
Diagnostics reported that code
Post #501664 15th Jan 2019 3:45pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
If there are no obvious leaks then look at steering angle sensor -- or height sensors -- if you have IID then try to read the live values for comparison Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #501666 15th Jan 2019 4:12pm
nighttimer
What is an IID?
Sorry a bit of a newbie to the rangeys, this is my first one
Post #501668 15th Jan 2019 4:15pm
Weegie
https://www.gap-diagnostic.com/products/iidtool/
If you wish to do any work on your FFRR then really an essential bit of kit. Even if you are getting work done by someone else the diagnostics put you in a very good position to know what to ask for.
Support from the company is beyond compare. John
GAP iiD BT-Sold
Post #501682 15th Jan 2019 5:35pm
Nick591
There are often IID tools for sale on the For Sale section of the site. I bought mine new from Duckworths (site sponsor). Best delivered price I could find. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #501724 15th Jan 2019 9:08pm
yelnats69
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
Did you manage to fix the suspension problem what was it
Post #541885 25th Jan 2020 7:00pm
