Home > Technical (L322) > trouble unclipping intercooler hoses at Inter cooler end
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
2003 TD6 - Removing the inter cooler hoses at the inter cooler end is there a trick. Stubborn hoses having trouble unclipping them ?
The spring wire clip do you push on the raised bit to unclip them or do you lever under the raised bit to unlock them.?
Post #502056 18th Jan 2019 11:56pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Pull clip down so it release’s out of the slot it will pull out quite far, and wiggle hose out.
Post #502069 19th Jan 2019 7:27am
lounge_on_wheels
I tried pulling on the clip but it seems jammed
Post #503000 27th Jan 2019 11:37pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
A different car but the 1st couple of minutes of this video might help
[/url] 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #503004 28th Jan 2019 1:43am
