![]() | Home > In Car Electronics (L322) > Code abs module, Td6 2002. |
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
Hi,
| tveitan Member Since: 10 Dec 2016 Location: Norway Posts: 47
I do have PA soft, but it won't connect to IKE or EWS so i'm only able to access engine and gearbox. I'll have to try and sort that out then. Think i've seen something regarding that somewhere, so i'll do a search. Thanks! |
It could be the dongle. I’ve heard that some Chinese examples have to have some of their wires repositioned and a little bit of soldering carried out |
It was |
Update: I now see that i need to read the file first, edit it, then write it. Problem is, there is no coding data to be read from unit. I'll put the old module in, read the file to my pc, put new back in and hopefully it will accept file from old unit. I'll give that a try tomorrow. Fingers crossed... 2002 Range Rover Td6 |
Hi,
No worries! That's good.
Let me know how you get on I’d be really interested to know how you get it working...... ______________________________
I put the old module in, and now I can't connect to any module at all |
Update:
| Ferret01 Member Since: 27 Dec 2018 Location: Kingscourt Posts: 5
An option could be ncs expert to code the individual module but you would need the specific spdaten for the l322 but I am not sure they are available. Some really good tutorials on line. Before you do any coding make a copy of all your modules this way if something goes wrong you have a back up.
I have ncs expert, but i'm not able to communicate with the car since it doesn't recognize the L322. I have an E39 as well, and i have no problem connecting to that car, so the software is working. Haven't found any way to comm. with the L3222.
I have finally managed to code the module with Tool32. It has a .prg file specific for the Range Rover which is L30 dsc57.
| Loyola1988 Member Since: 04 Mar 2019 Location: PARIS Posts: 8
Hello i have the same issue do you mean toolset32 ? i cannot find L30 dsc57 can you give me the path please and detail a little a tuto
