Home > Maintenance & Mods (L322) > 4.4 V8 not starting unless gears cycled? *RESOLVED* |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Welcome to the club
19th Jan 2019 9:18am |
gav525 Member Since: 25 Oct 2018 Location: Co Down Posts: 19 |
Cheers for the reply highroller.
19th Jan 2019 10:33am |
Unsure on the inhibitor type, but if the ECU thinks that it's in gear, It will not feed the starter. HDC can display on a low battery, so may be just coming on whilst the drain to start it. I would't worry about that at the moment (unless it doesn't extinguish).
19th Jan 2019 11:46am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
My 2004 L322 does it occasionally. I move the gearlever and it starts. I suspect the XYZ switch is out of adjustment after the transmission replacement.
20th Jan 2019 3:40am |
Either it’s the park inhibitor, where the gearbox isn’t quite recognising P or the selector cable needs liubing up under the car. Have a search is fairly common to have gearstick position probmlems in relation to what gear it’s actually in. A good spray of grease and a wiggle about will normally free it up. https://www.fullfatrr.com/forum/post87201.html#87201, There is nothing that can't be fixed with a hammer😜😜
20th Jan 2019 9:22am |
Perfect, many thanks for all the replies so far. Gives me plenty to look at when I get home again and hopefully get to the bottom of it.
20th Jan 2019 5:10pm |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 |
My XYZ switch went and cost me a shade under £600 inc labour at a local LR Specialist - only agreed cos he said he would fit a genuine part and I made my credit card company agree to pay the bill. Fitted a pattern part and managed to break my window switch in the process - another £300 . Never been back there since. |
21st Jan 2019 4:31pm |
Bruno were you experiencing similar symptoms to me then and did the XYZ switch fix it? |
21st Jan 2019 6:28pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 908 |
The 5-speed (bruno22rf) and 6-speed (gav525) transmissions have completely different types of inhibitor switch with the 5-speed one being mounted externally
21st Jan 2019 8:54pm |
Sorry I didn't spot that yours is a different model - but yes, mine had a similar fault somedays it was fine, others you had to move the gear selector up and down a couple of times before the engine got the message that it was in neutral - occasionally it would go into restricted mode whilst driving. |
22nd Jan 2019 1:37am |
Unnecessary quote removed
22nd Jan 2019 5:56pm |
OK so yesterday morning in the snow when the wife needed the RR most, it completely let her down. I'm still away until next week so trying to get as much info from her as possible.
24th Jan 2019 8:04am |
Finally go to the bottom of this!
26th Jan 2019 8:18am |
At least you know your linkage is ok. |
26th Jan 2019 10:21am |
