![]() | Home > General (L405) > Ugly kid glass - arrrgh! |
Flugplatz Member Since: 27 Feb 2014 Location: Cornwall Posts: 75 ![]() ![]() ![]() |
I used to think Trommel and I were in the distinct minority in disliking drug-dealer glazing on cars (generally, not just Land Rover product) - good to see another voice or two, it may lead to some softening of car-maker fascism on the subject (whatever happened to choice - for too many manufacturers, there's now no longer a choice, at least in the UK).
...if buying 2nd-hand, it is possible to have the offending tints replaced by clear glass, but on the 405 model the costs seems to have rocketed. Admittedly a few years ago, now, an L322 we bought for the family was de-privacy'd for around £1,500, which opened a much wider selection. Found myself recently teetering on the edge of buying a late-model 322 in green with clear glass as a gun bus... indecision meant it went, nothing similar out there, alas.
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
Green, plain, no privacy..... |
Looks good, doesn't it?! |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
Doesn’t it just? |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 288 ![]() ![]() ![]() |
I went down the clear glass route eventually when buying, but it wasn’t a straightforward choice.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
I used to hate privacy glass as I always thought that it looked “Sharkey”
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Interesting inputs from all.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1428 ![]() ![]() ![]() |
From memory it was £350 extra, clear being the standard spec. Only Range Rovers since 1988 |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
As mentioned above. If you find the 'perfect' car but it happens to have factory fitted privacy glass then you might be best getting a quote to have clear glass fitted from the likes of autoglass etc. I should imagine having it replaced at a main dealer would be extortionate.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8128 ![]() ![]() ![]() |
Fugly IMHO Get it wrapped in black and some pimp tints ![]() ![]() ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
The trouble without tints on a 405 is that the boot rear side windows look deformed due to the extremely large black border which doesn’t match the form of the other side windows. Therefore tints on a 405 look better imho 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
The thicker window surround is nothing to the vertical split in the glasshouse between front and rear. |
