Home > Maintenance & Mods (L322) > new struts camber adjustment
Blue Hornet
Australia 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I have recently replaced my front air struts and I am finding it difficult to get the camber adjustment done when I go to get an alignment. Originally I went to the dealer and that was another story.
The alignment place says they are unable to adjust camber on the front as there is a little plastic piece at the top of the new strut that has to be snapped off and also they don't have the land rover tool (LRT 57-045) see link: https://www.google.com/search?q=LRT+57-045...mp;bih=539
Currently they have left the front camber set at-
Left front 0 degree 13'
Right -0 degree 25'
I have read posts that say camber on the front should be - front left to 1 degree negative and right side .5 to .75 of a degree or 30- 45 minutes of 1 degree negative. Not sure if thats for left hand drive of if that matters.
My RR L322 2006 is right hand drive
Is the answer that L322 owners have to buy the tool if they don't want to go to a dealer
I would be interested to hear if anyone has got this sorted.
Bruce
Post #502802 25th Jan 2019 10:33pm
GraemeS
Australia
I'll be suggesting the nuts be sufficiently loosened to allow them to be tapped sideways as required.
Post #502807 25th Jan 2019 10:49pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
I'm with Graame, just loosen the 3 nuts securing the top of the strut and move it till it is in spec - not sure what the special tool gives you other athn a bit more control maybe?
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #502809 25th Jan 2019 11:42pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
considering the bolts/nuts that hold the strut to the hub, maybe there is suffiicient clearence of the bolts in the strut to slacken those off and adjust camber that way?
Post #502810 25th Jan 2019 11:48pm
Blue Hornet
Thanks guys.
OK thats sounds easy any idea about snapping off the little plastic piece in the attached photo as suggested in the manual?
Post #502811 25th Jan 2019 11:56pm
For all vehicles (up to 2010), the position of the studs should be marked before removal to ensure correct alignment on replacement or fitting of new strut, and thus the camber is retained. I am with the others, loosen three studs and tap with a hammer until camber is correct. You shouldn't "have to" snap off the plastic cone unless things are really out of kilter.... .
Post #502812 26th Jan 2019 12:04am
Did the alignment place settle the car properly before putting it on the ramp
It really needs winding up to top height, down to bottom access mode then back up to standard then driving for a few yards to settle it on flat ground. Either that or putting it into tight tolerance mode with a diagnostics tool.
See if you can find another alignment place who have a hawkeye and get the first places measurements checked out. To be that far out on the camber is odd, and shout be noticeable visibly I should think. There is nothing that can't be fixed with a hammer😜😜
Post #502824 26th Jan 2019 9:24am
GraemeS
Australia
Re: NEW STRUTS CAMBER ADJUSTMENT
Right -0 degree 25'
MY10-12 specs are -0 20 +/- 0 45 with max cross-camber 0 45 so both are within these specs but one positive and the other negative and the positive on the gutter side wouldn't make me very happy.
Post #502825 26th Jan 2019 9:37am
and when fitting strut everything should be tightened up with the "wheel on the ground", i.e. weight on suspension. .
Post #502836 26th Jan 2019 11:35am
Blue Hornet
Just cannot get enough camber by moving the top of the air strut to required settings even with LRT 57-045 Rolling with laughter
I have just purchased 2 Eibach camber bolts for my L322 2006 AJV8 Eibach website says the bolts give you +/- 1.75 camber adjustment so I think that will get me there. Rolling Eyes
Has anyone installed the Eibach Bolts??
Post #504861 11th Feb 2019 9:35pm
Bigvinno70
Ireland 2004 Range Rover Vogue Td6 Giverny Green
Just into the RR world and had LCArms replaced.. alignment place said everything was perfect but didn't know how to adjust front CAMBER..
1.. was happy that everything was ok
2... thought it would be straightforward for camber adjustment
Is it as simple as loosening the 3 bolts and tapping.. or doya need the LR tool
l322 range rover lrt-57-045 camber tool???
Post #701329 2nd Oct 2024 10:14pm
JamesDarby
United Kingdom 2011 Range Rover Autobiography TDV8 Buckingham Blue
Hi,
Its as easy as loosening the bolts and tapping across. Adjusted mine that way with no problem.
The little plastic point sticking up does limit the amount of adjustment. I guess if you needed a bit more you could snap it off or use a demell type device and grind a bit of the plastic away. 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #701349 3rd Oct 2024 8:38am
GraemeS
Australia
The plastic point is purely for ease of fitting the strut and should be removed if more adjustment is required.
Post #701357 3rd Oct 2024 10:42am
Scouse Exile
This is the way to go, I luckily had the foresight to mark the position of each of the three studs (after much research!) and it help enormously with a post fitment alinement.
You’d be surprised how much movement there is at the top of the strut even with the plastic retaining stud.
Jon
Post #701408 3rd Oct 2024 7:09pm
