Home > Technical (L322) > Fault on engine |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3694 |
First thing to check...., have the 4 short hoses been replaced ?
26th Jan 2019 4:57pm |
Tomo676 Member Since: 07 Aug 2018 Location: Aberdare, South Wales. Posts: 51 |
Forgot too say, my car is the FFRR 3.6tdv8 |
26th Jan 2019 4:59pm |
Ignore my reply then,
26th Jan 2019 5:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34972 |
check the inlet manifold for cracks.. |
26th Jan 2019 5:09pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Actually, still worth checking if any of the top hoses have split.... .
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
Could also be one of the large hoses from the intercooler to the intercooler has a split?
26th Jan 2019 9:45pm |
Sorry I meant from intercooler to inlet manifold.
26th Jan 2019 9:48pm |
It happens when foot down hard or going up hill. |
26th Jan 2019 10:34pm |
Same as mine. Most people found a split inlet manifold as the cause of this problem but not me. Basically the MAPT sensor (manifold air pressure and temp) detects the amount of pressure being delivered by the turbo. If there is an unexpected difference over a short period of time between what the sensor sees and what it thinks should be there it throws the fault.
26th Jan 2019 10:58pm |
Thanks Nick, is this maft sensor bolted into the manifold ? I'm a bit lost, not sure what to look for. |
26th Jan 2019 11:12pm |
Thanks Nick, is this mapt sensor bolted into the manifold ? I'm a bit lost, not sure what to look for. |
26th Jan 2019 11:13pm |
Take the plastic engine cover off. Look at where the two large intercooler hoses are connected to each side of the manifold. On the top of each side of the manifold just behind the hoseclip there is a sensor held in by a single screw. It has a grey plug. Remove the plug, undo the screw and pull the sensor vertically up and out. It has an o ring seal and should be easy to remove. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
26th Jan 2019 11:22pm |
Sorry I don't have a picture to hand.
26th Jan 2019 11:23pm |
Thanks Nick. |
26th Jan 2019 11:25pm |
