Home > Technical (L405) > Burned engine oil odor in cabin MY 18 SDV8
Lonfred
Spain 2017 Range Rover Vogue SDV8 Carpathian Grey
Any other here that has experience of burned engine oil odor in cabin. This odor apear in about 10 min of driving and it smells really nasty. The car has been in at the dealer and they said that they solved it and change a gasket but still this ugly odor. When I open the hood I can also see fumes just between the engine and the air intake. Maybe this is an known fault?
Post #502895 26th Jan 2019 10:08pm
gettingold
Could it be that they found the leak, changed the gasket but didn’t clean up the spillage = burning off?
Steve.
Post #502902 26th Jan 2019 10:50pm
Lonfred
Thanks. Could be like that. I give it another week to try to burn it of. If the odor then still is there then back to the dealer.
Post #502904 26th Jan 2019 11:06pm
There was an issue that some had with exhaust fumes -
https://www.fullfatrr.com/forum/topic24543.html
Post #502923 27th Jan 2019 8:52am
CS
Visible smoke in that area can be exhaust from the fuel burning heater, it comes on automatically under 5 degrees C, I don't know if that is relevant in Spain just now. If you drive only a short distance and then switch off, the car needs to burn off the fuel in the heater and that produces the visible smoke. It might make its way into the cabin if there are insulation gaps etc. The smell is unpleasant and unhealthy too, one would not want it in an enclosed space. Only Range Rovers since 1988
Post #503045 28th Jan 2019 2:21pm
