Home > Technical (L322) > Fault on engine
Tomo676
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
No Nick, don't have workshop manual.
Post #502925 27th Jan 2019 9:17am
theres a workshop manual downlink in the wiki....
Post #502926 27th Jan 2019 9:35am
Tomo676
Thanks Stan. Not sure how too get to it, but will have a look.
Post #502927 27th Jan 2019 9:38am
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I had the same fault recently. Eventually I tracked it down to the right side inlet manifold/ rocker cover. Now replaced, all is well.
Not to worry you, but the part is £400 and it is 6h labour. I did it myself and I can report it isn't easy, but it's doable.
Post #502928 27th Jan 2019 9:51am
Tomo676
I must be a lucky chap. It's a split hose.
Post #502931 27th Jan 2019 11:01am
GGDR
Good news Tomo, post up some pics and details... Thumbs Up
Suggest you update your car profile too.
. Cheers, Greg
Post #502937 27th Jan 2019 12:08pm
That is the standard failure point.
A few have had the manifold problem, however the majority of failures related to boost pressure can be be traced back to the split top right hand side intercooler to throttle body hose.
For reassurance, I would replace both sides at the same time, the LHS one is less prone to failure though.
For those reading this post in the future start here and work up in cost to repair......
https://www.fullfatrr.com/forum/topic26843.html There is nothing that can't be fixed with a hammer😜😜
Post #502940 27th Jan 2019 12:26pm
