Home > Maintenance & Mods (L322) > To do, or not to do? That is the ? Grease Wheel Hubs...
InversionLayer
United States 2008 Range Rover Supercharged Supercharged Java Black
Question for the group... it seems this has been discussed multiple places online, but with varying information (opinions). Curious if there is a consensus amongst this group with respect to greasing (anti-seize application) to the wheel hub: 1. spigots, 2. Studs, 3. Hub Mating Surfaces.
Info online warns about the dangers of 1. wheel stud failure due to application of incorrect torque once the stud is "wet" with anti-seize, or 2. That the wheel studs will shear off if anti-seize is applied to wheel mating surface.
The counterpoint is caution that without the anti-seize, the wheels become impossible to remove.
Consulting the Service Workshop Manual, it states:
BRAKING SYSTEM
... 6. Clean road wheel hub spigots and apply grease, Land Rover Part Number RYL 105020 to the wheel mating surface of each spigot.
I'm inclined to comply with the service manual... unless folks feel in experience otherwise? What am I missing?
Thanks,
Ed
Post #502793 25th Jan 2019 9:28pm
Paul thornton
I always grease the hub mounting surfaces and wheel nuts / studs. Don't even give it a 2nd thought.
Otherwise you just end up with wheel nuts that are impossible to un-tighten and trying to kick the wheel off as its seized in place.
Post #502827 26th Jan 2019 10:42am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
As per Paul Thumbs Up
Post #502837 26th Jan 2019 12:02pm
nino_nino
+1 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #502843 26th Jan 2019 1:08pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
+1 here too. I have just replaced my OEM nuts with stainless ones and dont fancy my new nuts sticking to the studs so applied copper slip. Retorqued after a couple of weeks and all good. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #502846 26th Jan 2019 2:52pm
Been greasing the wheel hub, spigots and wheel studs for the last 50 years.
Never use a torque wrench when fitting wheels, just do them by feel. Never had a wheel come loose yet.
Have you ever tried removing a LR wheel nut that has been torqued up dry after a couple of years use especially given the silly stainless steel covers on the nuts.
Post #502847 26th Jan 2019 2:55pm
DrRob
Always have used copper grease for last 40 years Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #502957 27th Jan 2019 1:51pm
InversionLayer
Thanks everyone!! A Thumbs Up
appreciate you all sharing your firsthand experience, I am going to proceed with the anti-seize.
Post #503005 28th Jan 2019 5:13am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Copperslip for sure, torque wrench settings may be slightly affected but from experience that can be ignored. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #503006 28th Jan 2019 6:50am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
What everyone else said!👍
I even go as far as removing the wheels of a new car and giving the components a good smear of copper ease just in case they need to be dismantled in the future.
Jim
Post #503008 28th Jan 2019 7:20am
