Home > Maintenance & Mods (L322) > Battery charger
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
I would've thought the charger would reach absorption (14.4 - 15V (AGM)) after just a couple hours if the battery already had 12.4V (approx. 75% charge level). 75% is usually about where the charger goes from bulk charge to absorption, where it stays until approx. 90% charge level and goes into float charge - 13.6V. 2007 L322 3.6 TDV8 Stornoway
Post #502995 27th Jan 2019 10:40pm
xjrsupercharger
CTEK MXS10 is brilliant. Use it on 3 different cars and just fit the quick connect leads to them all. I have a Bentley that spends weeks on charge with no problems 2015 L405 SDV8 Autobiography
ex 2008 RR Vogue TDV8
ex 2001 RR P38 4.6 Vogue
ex RR Classic
Post #503060 28th Jan 2019 4:35pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I have mine on a lowly Ctek MXS 3.6 and it's managing just fine to keep the battery topped up while I am awaiting delivery of a new starter motor. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #503081 28th Jan 2019 5:36pm
Had an MSX7 which combusted itself when charging a caravan battery....... Big Cry Rolling Eyes
I now have a MSX10 which is currently charging the battery on my M3, which it comfortably did overnight to full charge, and its now on trickle so im not left stranded at Tesco like I was last night! There is nothing that can't be fixed with a hammer😜😜
Post #503082 28th Jan 2019 5:37pm
Baltic Blue
NmJ,
I wish you hadn’t said that about “combustion “, because I am now on holiday and mine is plugged in to a CTEK 5 Big Cry Big Cry
Having said that, I have done it several times in past years.
Post #503243 29th Jan 2019 8:20pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I've used a ctek 5 for months at a time over several years with no trouble. On my previous L322 it was connected via a permanently live cig socket and now in my current one through the towing electrics. Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #503248 29th Jan 2019 8:31pm
Baltic Blue
Cheers Nomad,
I will rest better for the next 4weeks Rolling with laughter
I have left both B.B and my previous Td6 many times connected to a trickle charger. Thumbs Up
Post #503252 29th Jan 2019 8:39pm
Wasn’t on 🔥
Blew a resistor in the PCB. So was duff after. Not sure why tho. There is nothing that can't be fixed with a hammer😜😜
Post #503253 29th Jan 2019 8:46pm
