Home > Maintenance & Mods (L322) > Removing driver side side-light wing nut
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Any pointers lads? Struggling to remove it, limited room down the drivers side and it may never of been off Sad
Is there an easy way to remove the side light unit? 2003 model btw
Post #503210 29th Jan 2019 3:31pm
have an arm wrestle with the wife, if she wins then get her to undo it for you..
no easy way , maybe squirt some wd40 on it for a day ..
Post #503212 29th Jan 2019 3:47pm
This might help:
https://www.fullfatrr.com/forum/topic29062.html .
Post #503216 29th Jan 2019 4:08pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
If you have long enough arms, reach right under, it’s a bit hazy but iirc don’t attack it fromthe obvious direction. I might be mixed up & recalling the offside though Rolling with laughter
Post #503217 29th Jan 2019 4:30pm
Ballogie
United Kingdom 2004 Range Rover HSE 4.4 V8 Giverny Green
Take off the front grill
Loosen head light nuts
Pull headlight forward slightly
Just enough room to get at it
I dropped mine into the bowels when trying to reattach it - suggest tying a long piece of thread around it so you can recover it should you drop it
It is a swine of a job - prepare for skinned knuckles.
2004 model
Post #503258 29th Jan 2019 8:59pm
mrblonde
Joe90 wrote:
This might help:
I dont have much luck with them Joe, was hoping there was an easy way to access the drivers side one. Was kinda hoping Mr Tickle from Mr Men was on here Rolling with laughter
Post #503315 30th Jan 2019 1:24pm
mrblonde
2004 model
Thanks Ballogie...... I think. I’ll give it a go once it’s home (currently stuck in hospital car park as per my other thread) Rolling Eyes
Post #503316 30th Jan 2019 1:26pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
The light/indicator unit? Just the big white plastic thingy surely - you can see it from above - undo (long thread) then push the stud slightly away from the engine as you pull the unit forwards - my hands fit fairly easily?
Post #503345 30th Jan 2019 6:02pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Re: Removing driver side side-light wing nut
you need a snake with a monkies paw at one end....terrible piece of design .
Post #503447 31st Jan 2019 3:03pm
