![]() | Home > Maintenance & Mods (L322) > All Hail the IID BT Tool |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
be interesting to see what the Jaguar ACC Queue function does different to the default |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102 ![]() ![]() ![]() |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
On mine it stops the RR fully. Before change it would slow the RR to 20 kph then tell me to take over |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
Does it then move off again, or do you have to drive away yourself? Regards,
You have to depress the accelerator,,,, i tell it about global warming |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I'm keen to do this on mine. Has anyone come across any drawbacks?
Ticketyboo Too Member Since: 19 Mar 2015 Location: Kilkenny Posts: 38 ![]() ![]() ![]() |
Initial run this morning was very favourable, no indication initially that there was anything different until I came up behind slowing traffic at a roundabout - previously it would have bonged and lit up the dash to require driver intervention but this time it took me gently all the way down to stop. Further trials in a genuine queue situation to do, but promising beginnings. FF MY2010 3.6 tdV8 VogueSE |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
interesting, is it a built in function of the ACC? how does it sense it the car in the front?
It's utilising the radar behind the front bumper to determine proximity & speed of gap reduction etc. just as it would on the standard ACC, I'm guessing that this mod to the CCF is merely reflecting the code developed for later JLR models. It was a task of mere minute or two with the IID BT tool to upload the modified config and off you go. FF MY2010 3.6 tdV8 VogueSE |
Brilliant, I didn't realise there was a radar installed Current:
Yep, if you have the ACC then it’s there, it’s also used for the front distance alert. FF MY2010 3.6 tdV8 VogueSE |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
I like the sound of the queue assist - nice find |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Mark - if you have an IID tool, you just modify it yourself in the app (in the advanced settings or something similar from memory), and upload the modified CCF. |
Thanks for the quick reply Paul )
