![]() | Home > eBay & Bargain Spots > L322 bargain deployable side steps |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285
Don’t forget if you want to remove any wheels (to fix a puncture etc) the handbook advises you HAVE to remove the steps in order to access the jacking points on the chassis. |
Or a good top tip... Deploy your step then unplug it! It cannot try to close on you and gives you piece of mind when jacking up |
| S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170
I gave £174 for a complete set from Brit Part.
@Craig,
James, they unplug at the front hinge, just behind the sill cover... Very easy to unplug (when you know where they are) |
| mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214
I got a set from farnells via eBay for £375.I was going to fit them myself but on removing the old fixed side steps the first bolt sheared off when trying to loosen it. So took the fatty to land ranger in stockport for them to fit and they said every single bolt sheared off so def glad I didnt carry on myself..Very happy with them. 2009 Vogue SE Zermatt silver |
| topgeartowers Member Since: 23 Mar 2010 Location: London Posts: 83 |
This kit doesn’t contain all the bits you need - so for a new install, it would be more than the advertised price. |
Cable set was £111. Do you need more parts for a retrofit? 2007 L322 3.6 TDV8 Stornoway |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
You can also just leave a door ajar |
Turn ignition on, within 10s, hold the button for 3 sec. They'll then stay in their current positions until next ignition cycle 2007 L322 3.6 TDV8 Stornoway |
+1 for the above but i changed my wheels today and i used a forklift with strategically place lumps of 4 x 4 timber so the door method gave me piece of mind even though i sure the factory way would have been fine |
Thx hafsmo
In the roof console , where the button for the depolyable side steps is |
| All times are GMT |
