Home > Maintenance & Mods (L322) > Key problems
Tookmeechan26
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Key problems
Hi all i have a problem with my key when i insert it i the barrel the steering clicks as it should but key wont turn to start if i wiggle it pull it push it it will turn but then when i switch it off i have the same problem now i am not getting a click ut the steering isint locked any help please
Post #503683 2nd Feb 2019 4:17pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
Have a quick look on the wiki, scroll down for electronics and the topic you’re looking for is the third one down.
Good look ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #503684 2nd Feb 2019 4:20pm
Do you have a spare key? Have you tried that yet?
Post #503685 2nd Feb 2019 4:22pm
Tookmeechan26
Hi spare key is just the same problem
Post #503686 2nd Feb 2019 4:26pm
Battery in charged? Do you have a jump pack?
Post #503688 2nd Feb 2019 4:34pm
Tookmeechan26
Battery is fine
Post #503691 2nd Feb 2019 4:47pm
Have you checked the cable from the gear shift to the ignition switch is moving/working/free?
Post #503692 2nd Feb 2019 4:53pm
Tookmeechan26
Took of the gearstick cover and the silver leaver was stuck think its attatched to a solinoid got it moveing free and thats when the clicking stopped at the steering wheel but key still wont turn where is the cable you speak about
Post #503696 2nd Feb 2019 5:15pm
When you put the stick into P it pushes/or pulls a cable (much like a bicycle brake cable) thie other end goes to the key barrel . Basically, when you select P it allows the key to turn... When you select a gear the cable locks the key in the ignition. You then cannot remove the key until P is selected again.
If the cable is stuck or stiff it won’t let the key turn...
Post #503732 2nd Feb 2019 9:23pm
Tookmeechan26
Thanks will have a go tomořow and let you know cheers
Post #503749 2nd Feb 2019 10:19pm
Tookmeechan26
Hi again after a few hours getting to the bloody thing everything seems to be workjng fine cable is free latch is free but the key still struggles to turn u less i pull it push it wiggle it so i am thinking its the barrell at fault o ly thing now is when i switch it off i can now remove the key easy but just a struggle to start can i get a barrel and key from ebay a d plug and go or will it need programed sorry to be a pain but this is driving me nuts
Twisted Evil Laughing
Post #503837 3rd Feb 2019 6:36pm
The immobiliser is a little black square magnetic block in the top of the key fob. This is read by a ring around your ignition switch, this also works the steering lock (i think... from memory) so..... If you buy a lock & key from fleabay then the magnet would need transferring, the door lock would need changing along with the glovebox lock... The key would need coding to your car of which I'm unsure if a second hand key could be?
The next thing i would try, if you have the time? & patience? Would be to remove the ignition lock and tap in upside down and see what falls out! The reason for JLR moving the key higher in 07MY was simply because dirt and especially sand would gather in the lock and jam it up!
Good luck Thumbs Up
Post #503842 3rd Feb 2019 6:47pm
Tookmeechan26
Cheers i have sprayed and filled it with elect. Cleaner and wd40 and also some clean oil as i said i can now remove the key after switch off but still a bit of fecking about to start
Post #503843 3rd Feb 2019 6:51pm
