Home > Maintenance & Mods (L322) > Revs drops to nearly zero? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3059 |
Dirty MAF |
26th Jan 2019 11:19am |
gav525 Member Since: 25 Oct 2018 Location: Co Down Posts: 19 |
Will be the first thing to check when I get home next week then, cheers 2006 Vogue 4.4 AJV8 |
26th Jan 2019 12:16pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1240 |
MAF + 1 V8 or else ... |
26th Jan 2019 10:11pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
MAF + 3
27th Jan 2019 12:32am |
Cheers all for the above advice. Back in the UK now for a month so have the time to look at things properly now.
2nd Feb 2019 6:53pm |
Air filter dirty/blocked?
2nd Feb 2019 7:06pm |
Will check air filter and intake tomorrow. Will be giving it a full service soon so will stick a new fuel filter in and check pump and injectors also.
2nd Feb 2019 8:30pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
I don't know the engine but that sort of behaviour is typical of a sticky idle control valve.
2nd Feb 2019 8:36pm |
Rovah Member Since: 12 Apr 2018 Location: MO Posts: 5 |
Have you figured out a cause and solution for the rpm drop? |
3rd Mar 2019 5:15am |
Nope, I'm back at work for a month so haven't had a chance yet.
3rd Mar 2019 8:21am |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
I have had exactly the same problem with the revs nearly dropping to zero, as well as the car stalling on start up when when the engine was warm. It turned out that my vacuum system wasn't connected correctly and air was being sucked straight into the inlet manifold through the PCV valve.
3rd Mar 2019 8:34pm |
Mine is the AJ V8 but I'll be taking a good look at the vacuum system anyways. 2006 Vogue 4.4 AJV8 |
4th Mar 2019 11:02am |
Walkeraj101 Member Since: 25 May 2019 Location: Wirral Posts: 3 |
Hi, bit of a late response but I had this issue on my M62 4.4 v8 and it was MAF and diaphram had split inside the crankcase breather on back of air intake manifold. Had to replace both and all was good after that. |
15th Jul 2019 10:13pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Had same issue. Turned out the MAF and throttle body were both dirty. |
27th Jul 2019 1:40am |
