Home > Maintenance & Mods (L322) > wiper blade size
Northern lad
wiper blade size
hi all
does anyone have a definitive answer please? I want to get both front and rear blades replaced, but there are a lot of conflicting sizes out there, 18" both sides, 24" one side 18" the other?? and does it really matter
i looked through RAVE no luck, i looked through WIKI no luck..
the ebay ones look favourite (directly below) , i did get a price from Dan (Duckworths) some months ago, but a lot more expensive
https://www.ebay.co.uk/itm/RANGE-ROVER-L32...SwT4lWTPE6
http://vi.raptor.ebaydesc.com/ws/eBayISAPI...&ver=0 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #503634 2nd Feb 2019 9:14am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I bought these a few months ago, perfect fit for the fronts from the same seller as one of your links for the front and back.
https://www.ebay.co.uk/itm/RANGE-ROVER-L32...em3d3e72e4 Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #503647 2nd Feb 2019 11:04am
DrRob
Get some modern aero blades on it
I bought these https://rover.ebay.com/rover/0/0/0?mpre=ht...1738271428
Superb value and fit. Strip off the horrible brittle plastic blade mounts to leave the open jaw on the metal arm. New ones click into place.
Pour a beer Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #503665 2nd Feb 2019 12:47pm
Northern lad
thanks chaps for your replies
my god its turning into a bit of a minefield this! I had to go out yesterday, so I measured mine. front are both 25" rear 17&3 quarters"
Dr Rob I like the look of the Aero's 26" i beleive so if you have them, there is obviously no problem with them hitting each other, however sounds a bit of a faff fitting them?
Bradders do you know what length they are, I cant find the product dimensions?
I looked at these on Amazon (it clearly states it fits my vehicle) however, I zoomed in on the bottom of the packing image, and the connection type doesn't look right?
https://www.amazon.co.uk/BOSCH-Super-Plus-...B0041UNUWU 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #503775 3rd Feb 2019 10:33am
DrRob
Censored
Just realised yours is a 2003. Ignore my post. Later models only
Sorry Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #503776 3rd Feb 2019 10:39am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
no faff fitting the aero's!
the only 'faff' was understanding how to fit them but once understood it takes about 10 seconds for each one.
1) lift each blade up and fit a towel underneath them to protect the screen
2) remove everything on the end of the arm, all bits of plastic (some of which collapse in any case) so all you have left is the metal arm
3) clip the aero on
as regards length, the same as what you currently have !
Post #503777 3rd Feb 2019 10:42am
Bradders
Both front ones measure 25" and the back 18" and that's on a 2012. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #503782 3rd Feb 2019 11:42am
Northern lad
I have found these, and have sent the seller a message in regard to length, no reply yet.
just need to get the rear one sorted.
he is pretty confident they will fit, so much so he is offering to pay for a new Range Rover if they don't! I wonder if I can change the wiper arms to something completely different Whistle Thumbs Up 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #503872 4th Feb 2019 6:02am
Woofster
Canada
Both fronts should be 25.5" and the rear should be 18". 2010 RR SC
2007 RR SC
Post #503953 4th Feb 2019 7:46pm
Ballogie
United Kingdom 2004 Range Rover HSE 4.4 V8 Giverny Green
cheaper on ebay https://ebay.us/2IoXvb
Post #503961 4th Feb 2019 8:43pm
psgk
Hello Ballogie,
You can fit a 20" blade to the rear wiper arm. I've just renewed the blade on my MY2002 Vogue. I used a 20" Bosch blade purchased from Halfords
I followed this suggestion made by another owner thats buried in a post somewhere on this site. Improves the area of the rear screen swept by the blade
Hope this helps Peter Kemp
Chelmsford
UNITED KINGDOM
Range Rover Vogue MY2002 4.4l V8
Java Black
Charcoal Trim / Oxford Seats
Colour Coded: Door Handles, All Badging Front and Rear, Bonnet Vent, Foam A-Bar / Nudge Bar
Range Rover Style 11 20'' Wheels
US Spec Front Sidelight / Indicator Light Units / Rear Light Units (MY2005 Style)
Retro Fit Sony / Alpine RES
Various LED Light upgraded Interior / Exterior
Lower Rear Tailgate Gas Strut modification
Post #505552 18th Feb 2019 12:18pm
probably anything from a 14 inch to a 20 inch will fit ...
as i cant see the whole rear window in my rear view mirror i've fitted a 14 incher..
Post #505554 18th Feb 2019 12:39pm
