![]() | Home > Technical (L322) > Heavy Steering FIXED ! |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 341 ![]() ![]() ![]() |
Any fault codes? |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
No Codes at all i am afraid |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
Was the replacement BCU a new one or secondhand ?
Hi
Symptom just noticed
Neil,
Yes i am beginning to suspect wiring as well, if i could get hold of a wiring diagram for the BCU i would like to bell out the connections to the ABS ECU and the Servotronic Valve |
What model is your RR ?
Mine is the 2006 Facelift model , ie touch screen and TV in the dash.
I think i have worked it out.
Neil,
Thanks for the wiring diagram
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Apologies if this sounds stupid, but you haven't taken fuse 41 out have you, the one for the rear wiper? |
Fuse 41 is in , i did take it out to check and it was fine.
