Home > Maintenance & Mods (L405) > Fuel burning heater run time |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
20 mins is about right (assuming good state of battery charge).
4th Feb 2019 11:58am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
It only uses 15w of energy at 2 amps so it's actually much lower than you think... at least according to webasto thermotop c, and that is an older model... |
4th Feb 2019 9:03pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 350 |
I don't have an FBH in my L322, but do have the large ThermoTop C on the sailing boat as part of the central heating system, and it's fairly economical in terms of amperage when running (~2A as below), but noticeably increases to >10A during start up and cool down periods for maybe 1 min each, so definitely needs a good battery to kick it into life. |
4th Feb 2019 11:07pm |
Ahhh, but that's just the FBH unit. If you actually have park heating and not just an FBH that warms the block, then the blower from the HeVAC also runs, which will perhaps pull a few amps no doubt. |
6th Feb 2019 1:58pm |
