Home > Maintenance & Mods (L322) > Speedometer accuracy question.
Busterbulldog
Wales 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I thought 30mph felt especially slow in the range I bought a few weeks ago.
I passed a few of those show your speed things on the road yesterday, 30 mph on my speedo shows as 24mph on the road display. Why would it under read so much ?
Post #504298 7th Feb 2019 2:45pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Has someone fitted undersize tyres to the car ? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #504311 7th Feb 2019 4:09pm
i wouldnt take for granted that the 'road speedo' readouts are that accurate...get an aftermarket gps that shows the mph..
Post #504312 7th Feb 2019 4:15pm
rjff
Your car speedo is not necessarily reading the actual road speed. As Pawl and Stan say, tyres and sign accuracy come into it. I found this bit some time ago which seems to indicate that the regs give some leeway to overreading, but do not allow the speedo to under read. Again, that will depend on the tyres and anything else the manufaturer uses in their design.
http://www.legislation.gov.uk/uksi/1986/1078/regul...
There's this bit in Section 19
"1. The vehicle shall be fitted with a speedometer capable of indicating speed in mph at all speeds mph. up the maximum design speed of the vehicle.
2. For all true speeds up to the maximum design speed of the vehicle, the true speed shall not exceed the indicated speed.
3. For all true speeds of between 25 mph and 70 mph (or the maximum design speed if lower), the difference between the indicated speed and the true speed shall not exceed—
V / 10 + 6.25mph
where
V = the true speed of the vehicle in mph."
http://www.legislation.gov.uk/uksi/1996/3013/sched...
Thus at a true speed of 24 your speedo could be indicating 32.65. Cheers
Richard
Gap IIDBT
Post #504321 7th Feb 2019 4:58pm
Busterbulldog
I appreciate that the speedo is not totally accurate , but I have had several people overtake me on a 30 limit . 6mph seems too much to be out. I have a transit and a freelander which are both accurate to the display mph at 30.
I bought the car with the wheel tyre combo it has but cannot say if they are correct in size. I will upload a pic maybe someone will know.
Tyres are 255,55 r20
Car is 2007 ajv8
Post #504375 7th Feb 2019 8:46pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I had that size on my 2007vse and my 2011vse and the speedo was very accurate according to the App i use ( Speedometer) Also road side speed warning signs that i pass everyday agree with the App Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #504378 7th Feb 2019 8:56pm
Nick591
My 2008MY 3.6TDV8 on 255/55/20 Wheels and tyres reads about 2 to 3 mph under true speed. Thus at 50mph on my Sygic satnav the speedo is showing around 52. Same difference at 30 and 70. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #504394 8th Feb 2019 12:32am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Switched to 22" wheels from 20's.
So used my IID Tool - great thing and well worth buying if you don't have one - to set my tyre sizes up.
All the road side warning signs agree with the speedo within +/- 2mph What do I put here then?
Post #504404 8th Feb 2019 10:16am
Busterbulldog
So it's likely these are non original wheels and it needs an adjustment then via someone with the correct equipment ?
Post #504407 8th Feb 2019 10:22am
you need to have a look at what's on first and go from there....post a pic or the size ..
Post #504408 8th Feb 2019 10:27am
Busterbulldog
All posted above
Post #504409 8th Feb 2019 10:29am
Embarassed
wheels look ok, tyre size will make the actual mph to speedo slightly more accurate...get or borrow a sat nav and compare your speedo to it..
Post #504411 8th Feb 2019 10:38am
GAC23
Sorry, that's not what I meant.
Using the IID Tool you can check - and change if necessary - the settings your speedo uses to calculate your speed. What do I put here then?
Post #504414 8th Feb 2019 10:53am
Busterbulldog
What is this tool I need and where would I find it and how much will it cost ? Or should I just book into a dealer for adjustment ?
Post #504442 8th Feb 2019 1:15pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Buster,
I run the same wheels and tyre sizes -- and all is well with my setup.
The IID tool is a way to make changes to the car and diagnostic -- a very useful tool all round -- if you want a new one there's a good price from Duckworths on the forum here!
However, for the time being, Stan is absolutely correct -- get a sat nav that displays your speed and go and do some comparisons, if your speedo is readin slower than the display on the Nav you can be pretty sure it's not the rims or tyres -- you'll be needing to look at another issue
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #504444 8th Feb 2019 1:22pm
