![]() | Home > Maintenance & Mods (L322) > Nav unit failure (MK4) |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Drivnig to work today and the head unit rebooted four times then froze!!!!!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
first thing i would do is to take the disc out , inspect and re-insert..check for water ingress or damage...a battery dis-connection and re-connection might help if al is ok in the the first suggestion .. ... - .- -.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Apparently it's a common fault, you can buy a fix on ebay for £150, or replace the laser unit yourself if you're brave enough! 2012 SDV8 Vogue SE |
If its the laser then i'm fine woth doing that myself. Dont think there is any water ingress - the car is always garaged and never had water issues before (but will check). "On first name terms with my local Dealer......now."
