![]() | Home > Maintenance & Mods (L322) > Rear Disc Brakes - Question |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
You can slacken off the handbrake shoe adjuster manually, then just remove the disk. It might be necessary to electronically drive into the mounting position if you need to replace the handbrakes shoes, but they can be cleaned up quite well in posisition in my opinion. Current: 2010 Range Rover L322
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
You dont need an iid tool. Get the car all ready key in position 2 and chocs under the front wheels and other side your not doing then select neutral and release the handbrake. Keep the button pulled up and then turn the key off. You can then have the rear wheels free to spin to locate the adjustment cog so you can get th old disc off by slackening it. Plenty of guides on here and search bodsys brake bible on google for the replacement and readjustment procedure once both sides are done. Current 2007 TDV8 Vogue Buckingham Blue |
Or it could be hold down the andbrake button actually when you turn the key off thinking about it now Current 2007 TDV8 Vogue Buckingham Blue |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Thanks.. is it not that the parking brake is applied automatically when the door is shut? I read somewhere here there I should leave the door open. Current:
Parking brake is not applied automatically on MY 2010. I understand that can be enabled in CCF from 2011 onwards. Even then, it is applied when ignition turned off, not when door is opened. Current: 2010 Range Rover L322
Cheers..
Theres a bit more to it as you need to loosen the cog off take the disc off. New one on and tighten the cog then back it off and then do the handbrake adjustment process which invokves driving and pulling the handbrake on a few times Current 2007 TDV8 Vogue Buckingham Blue |
This is from the d3 forum but has most of the info needed. https://disco3.co.uk/gallery/albums/userpi...1.4sml.pdf
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Have a look at Bodsy’s Brake Bible, Version 1.6a
Might help but I’m not 100% sure the EPB function is same. Caveat.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
I did mine on both my D3 and my FF (2009) using Bodsy's brake bible. They are very similar though i remember there being a few very minor differences.
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Not sure if it's off any use but I think when DM did my disco EPB unjam I am sure he said you don't need to bed them in
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
If you are just replacing the discs then its a simple job. Same as doing combination of disc and drum brakes.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
I have EPB fuse as number 36 / 5 amp
