|  | Home > In Car Electronics (L322) > Static on all radio channels |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | this shows where the antennas are..
|  29th Jan 2019 6:21pm |
| Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259      | Thanks Stan. Very useful.
|  29th Jan 2019 6:47pm |
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204      | When i charge my phone in car using a usb adapter in the aux plug i get static on the radio pull it out and it goes back to a perfect signal,a bit annoying but just put spotify on instead. _____________________________________________________
|  30th Jan 2019 10:17am |
| Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259      | @Scottyav. Nothing plugged in to AUX. However today no static on radio channels, but I did get the 'Transmission Fault - Traction Reduced' message on startup.
|  30th Jan 2019 10:07pm |
| Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266    | I have had the same problem, mine was caused by the coat I was wearing. If the problem occurs, I exit the car close the door. remove said coat and get back in. works every time.
|  10th Feb 2019 12:27pm |
| Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259      | Hmm. OK. I'll try driving around in the nip to rule out clothing related issues. What could go wrong? | ||
|  11th Feb 2019 10:39am |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102      | You could get a flat and have to change a wheel -- still look on the bright side -- it'd be a place to park your bike :O Current: 2011 FFRR Vogue SE 4.4 TDV8
|  11th Feb 2019 11:02am |
| Posting Rules
 ), a couple of days ago I had a 'Transmission Fault - Traction Reduced' message a few times on startup. No fault codes were thrown and and I had 14.7 volts with the engine running. but I understand that this fault can be triggered by a failing battery.
