![]() | Home > Maintenance & Mods (L322) > New noise |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
When I turn off my engine there's is a high pitched wine coming from the centre front on the engine compartment. After a minute or so there is a glug sound and the noise stops suddenly. Any ideas as to what it might be and is there a problem that need attending to? |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
I've just got ours out and have heard the same thing. It seems to happen every time I shut the engine down, but only heard if I have the bonnet up and head near. It appears to be the throttle body making the whine and then that "glug" seems to be it finding its rest position. I have recently replaced the throttle body due to other faults coming up and the new one is still making that noise. Thus I am not concerned about it, yet.
Thanks for your comments. My sound seems to have become louder recently. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Diesels dont have a throttle as such, I know theres a device that looks like a throttle body is that it's real function? My Touareg had a very similar item, in the case of the VW it was an 'anti shudder valve'. It was closed during shut down of the engine to stop a wobble, one cylinder was always going to be on compression and caused the engine to shudder when stopping. By closing the valve (throttle) the compression cylinder had no air and therefore wasnt compressing resulting in no shudder.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2731 ![]() ![]() |
It is a throttle and is used to close-off fresh air to cause more recirculated air through the EGR valve. |
Webbie
The 4.4 TDV8's EGR throttle isn't closed by the ECM on shutdown which is why I developed my add-on module. I'm pleased to read that the Touareg closes off intake air on shutdown as mine's engine now stops slightly differently - I thought more abruptly but perhaps more smoothly as it seems there is no run-down. |
rjff, the engine runs fine and no shudder on shut down. |
Webbie
