Home > Technical (L405) > Strange noise on acceleration
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Hi all, on my seventh Full Fat RR but new to the site. Bought a 2013 L405 a few months ago. Question I can't find an answer to : if I accelerate from standstill, uphill, sounds like a pendulum weight moving back then forwards again. Sound seems to originate from under the front passenger seat. Any thoughts appreciated (no, I don't have a clock under the seat as afar as I'm aware !)
Post #505398 16th Feb 2019 8:52pm
check for something in the passenger door pocket. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #505404 16th Feb 2019 9:34pm
roberlar
Only item in the door bin is the headphones in a fabric bag which would be more of a muffled noise if anything. The only way I can describe the noise is like a weight on the end of a vertical coil spring moving backwards under acceleration and then a bouncing noise when coming to rest. Odd I know! None the less I'll take the headphones out and see what happens
Post #505447 17th Feb 2019 11:14am
have a look under the car at the passenger seat location..
Post #505448 17th Feb 2019 11:55am
Baltic Blue
Check that the passenger side seat belt retractor is working correctly.
It is mounted in the bottom of the door pillar. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #505457 17th Feb 2019 12:33pm
roberlar
Thanks for the tips. Had a look under the car and can't see anything loose or untoward. I'll check the seatbelt operation next.
A thought that crossed my mind today is the massage mechanism in or under the seat, but not having a mental picture of how it's put together I'm not sure. It makes no difference with a passenger on the seat, but I'll see what happens with the massage running. Either way it's not too much of an annoyance as it only occurs on fairly sharp acceleration uphill from a standstill. It's more a wooden or plastic type of noise, certainly not metallic. Something is moving backwards and then returning to its normal position with a kind of 'boing' sound, which is always exactly the same.
Post #505495 17th Feb 2019 7:22pm
Ukandrewf
I have a 4.4 2017. I’m getting a whining noise on acceleration. Any ideas what that could be?
Thanks --
On my third Full Fat RR
Post #586808 9th Mar 2021 5:39pm
roberlar
After about two years I discovered the culprit in my case.....the air con filter housing box near the glove compartment has a curved hinged lid rather like a kitchen swing bin hence it was opening and closing on hard acceleration / deceleration. Very much doubt that's your problem though, more likely transmission noise of some sort if it's whining or air intake / turbo intake if it's whistling
Post #586823 9th Mar 2021 6:46pm
Whining on acceleration, is probably drivetrain related, possibly transfer box or diffs. have the oils be changed on these? There is nothing that can't be fixed with a hammer😜😜
Post #586826 9th Mar 2021 6:57pm
Merchy
Whining noise under acceleration ? maybe her indoors has just seen the fuel bills Rolling with laughter
My Ex loved fast cars, but complained like hell if she had to pay for fuel, so I bought a Jensen. Her comments were along the extremely Censored variety, once she found out about 8 or 9 to the gallon, she's long gone but I still have the car Laughing
On a serious note, have a look at any mounting brackets under the passenger side,any gearbox / driveshaft / transfer box / brackets or bushings ? Hope it's not serious.
Post #586844 9th Mar 2021 7:53pm
