Home > Technical (L322) > 2010 Autobiography surround cameras |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Well that's a first!
19th Feb 2019 9:07pm |
V8driver Member Since: 12 Aug 2017 Location: Kent Posts: 8 |
As far as I'm aware they did fit the correct part. The rear camera works for about 10 seconds then turns off and camera system fault comes up. I'm going to try and contact the previous owner to see if they had any problems with it. To be fair to the dealer i bought it from he has tried to sort it buy fitting the module, a new rear camera and paid for the dealer to code it. |
19th Feb 2019 9:57pm |
ilard Member Since: 21 Oct 2012 Location: London Posts: 698 |
I suspect bad fitting, bad module, or a gremlin deeper within the electrics, especially since rear camera is not working. Sounds like expensive diagnostics needed... |
19th Feb 2019 10:06pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
How do you know you've got them fitted?
19th Feb 2019 10:51pm |
Because you can see them. And they are part of blind spot monitoring. Also build spec states surround camera system. It's as if it's been deleted from the media screen |
19th Feb 2019 10:58pm |
The module for single camera and surround cameras are different are you sure they didn't fit the single module? Current: 2011 FFRR Vogue SE 4.4 TDV8
19th Feb 2019 11:14pm |
I've got the box from the one they fitted. I think I'll double check the part number tomorrow just incase. Can't see any loose plugs hanging around though |
19th Feb 2019 11:20pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
My initial thought when I saw this was that they've fitted the wrong module. But do the non-surround camera equipped cars even have a camera module?
20th Feb 2019 8:59am |
The odd thing is that there's no option to select the cameras at all. I'm going to try and contact the previous owner and ask him if there was a problem or if they even worked as mentioned. They definitely fitted a new part so unless that's also faulty the only thing i can think of is that is not been reprogrammed correctly |
20th Feb 2019 9:06am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16169 |
I’m sorry but I have little experience with the camera systems but I will say this... I have had to replace quite a few single camera’s that have failed, front side and rear... The other thing I have found on my 405 inadvertently was this, when I took the front bumper off, I fitted the two cameras the wrong way around! So, the left side in the right side and visa versa, even though they are the same cameras L&R! Same part number! And the complete system shut down! NO response from the soft button or engaging reverse gear!
20th Feb 2019 9:58am |
