Home > Technical (L322) > Access mode annoying gremlin |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 396 |
Had the same issue, not sure on exact fault but if you have a warranty then possibly covered.
20th Feb 2019 10:20pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
I had this problem that got progressively worse. It is because the exhaust filter for the suspension compressor is getting clogged with age.
25th Feb 2019 2:11pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Thanks for the reply buddy.
25th Feb 2019 2:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34908 |
this ,from our wiki, will help,
25th Feb 2019 2:35pm |
Many thanks |
25th Feb 2019 2:37pm |
HMM... Turns out the silencer is not avaliable on its own anymore?
25th Feb 2019 4:24pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Try it with it out, you'll know if that's the issue then Current: 2011 FFRR Vogue SE 4.4 TDV8
25th Feb 2019 4:25pm |
^ what bushy says and if it works then drill that hole.. |
25th Feb 2019 5:36pm |
