Home > Technical (L322) > One EGR error cleared now a new one
kbald
Hi all i had the error P0407-21 (2D) Exhaust gas recirculation sensor B circuit low - General signal failure - signal amplitude<minimum so removed he throttle bodies and gave them a thorough cleaning and this code has now cleared but i have a new code in its place P142D-21 (2F) Exhaust gas recirculation sensor D circuit low - General signal failure - signal amplitude<minimum
So similar but a different code and sensor so it seems. Does anyone have any clues as to what the new issue is or what the sensor it refers to is? Thanks in advance Current 2007 TDV8 Vogue Buckingham Blue
Post #506122 23rd Feb 2019 8:31pm
kbald
Solved
For anyone that has this in the future the error was caused by the cable at the bottom of the lh (nearside) throttle body not being fully pushed on. I believe the first code was the same on the rh one. Now no fault codes! Success. Current 2007 TDV8 Vogue Buckingham Blue
Post #506190 24th Feb 2019 2:32pm
