Home > Maintenance & Mods (L322) > Drivers seat switch surround panel |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 194 |
The dull chrome like film on the drivers seat switch surround panel is lifting off. Is is possible to sperate this part from the rest and replicate the chrome like finish ?
26th Feb 2019 3:23am |
Jsteed Member Since: 14 Feb 2019 Location: Uk Posts: 2 |
Hi, yes the chrome trim is removable. I have the same problem.
3rd Mar 2019 5:07pm |
Cheers. Think I'll take a chance on the AliExpress stuff and see how it goes. |
5th Mar 2019 1:46pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Looks like your seat foam has failed which means you are now flexing the chrome trim and this lead to the chrome finish delaminating, your new trim will do the same and eventually crack if you don’t replace the Lower seat foam. |
17th Mar 2019 9:48am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I would agree with what ur20v says. I'm surprised that the side panel is still attached. But changing the foam I assume would be a PITA (excuse the pun) anyhow. |
17th Mar 2019 10:46am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
An easy non expensive fix would be to take the two front seats out and change the seat base's over... The outside of both will then be like new |
17th Mar 2019 11:28am |
This is the passenger seat, which doesn't look that worn next the drivers side.
17th Mar 2019 7:35pm |
Those Aliexpress parts look great for the price! I look forward to hearing how you get on with fitting them. I'm sure they will fit fine.
4th Oct 2019 5:57pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1132 |
Hi, Price for seat base from Duckworths £94 filler part £38 this is for a 2011 year |
5th Oct 2019 9:18am |
