Home > Maintenance & Mods (L322) > 110ah battery fit
Andy
110ah battery fit
I have a new 110ah battery on my TD6 and I’ve just tried to fit it to the TDV8
It goes in but the positive cable looks like it’s meant to sit down the side of the battery but there is no room
The car was supplied with a 110ah battery according to the build sheet.
Anyone else had this and how did you get around it?
[/u]
Post #506464 26th Feb 2019 3:13pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Ur -- this is covered in other posts -- not least one of my own, whilst an 020 battery will fit earlier models, 2010-2012 will only accept a 019 -- amp-hours aren't always related to size!
The battery should be AGM -- but as in other threads I'm testing a non AGM solution as it came with a 5 year warranty and was specified by Halfords for the car -- whilst the battery isn't knackered yet I can report it wouldn't start the car on one occasion so far Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #506466 26th Feb 2019 3:24pm
Andy
Thanks. It’s got a 100aH /900a on at the moment which I’m told was new in November. However there is no receipt with it and it’s got a 5 yr warranty.
I take it a 100aH is plenty for this car?
Post #506469 26th Feb 2019 3:32pm
Bushy30
Well mine is this: -
Yuasa HSB019 -- which is 100Ah -- and a CCA of 900 Amps
They also do the HSB020 which is 110Ah, cheaper to buy, so I started with that one -- and found the same problem you're having -- it don't fit! -- and actually it doesn't fit front to back either -- I could only just about get the clamp on it in a modified state -- fortunately I could unmodify it to fit the 019 Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506473 26th Feb 2019 3:48pm
Andy
The battery on this one is Yuasa. Must be the same one
Post #506476 26th Feb 2019 4:01pm
Bushy30
If it is the same as the HSB019 then it's the wrong one for the car -- the HSB019 is not an AGM battery -- and the car should have an AGM battery fitted
Though I suspect that if you run your reg at the Halfords web site it will suggest the HSB019, as it did for me Sad Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506477 26th Feb 2019 4:12pm
Andy
Where does it say it has to have an AGM battery then?
Post #506479 26th Feb 2019 4:21pm
Bushy30
Most earlier versions of the 10MY were fitted with non AGM and were subject to a recall to fit AGM I believe.
Search for threads here -- there's a few!
But here's mine: -
https://www.fullfatrr.com/forum/topic48879.html?highlight=agm Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506484 26th Feb 2019 4:39pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
you MUST fit the correct battery type agm or NON agm depending upon what your car is expecting. I've been through the painfull loop of trying the cheaper (but incorrect) option.
My car is 2010 so i assume newer cars such as your also require agm.
Post #506487 26th Feb 2019 5:09pm
Bushy30
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506488 26th Feb 2019 5:14pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I have a 020 agm in my 2011 VSE, tight fit but does go in Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #506510 26th Feb 2019 8:55pm
Bushy30
Dolph, did you manage that and still have the scuttle drain pipe connected? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506520 26th Feb 2019 9:29pm
dolph34
I have to admit that the indie i use fitted it for me so i dont know. I will jave a look tomorrow. I know he remove the plastic trim at each end of the battery. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #506523 26th Feb 2019 9:36pm
Tight777
My 07 TDV8 has a non original AGM fitted, its due for replacement but not sure what to fit, non AGM 020?
Post #506565 27th Feb 2019 10:38am
