Home > Technical (L405) > where do the drainage pipes for the sunroof exit the car |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi folks, I want to check if my drainage pipes for the sunroof have issues as I am getting a damp drivers side carpet and from other forums , this has been an issue on Discoverys and the old RR Sport due to the sunroof drain pipe grommet coming out of its hole in the wing/bodywork and so the water ends up running down the inside of the car into the footwell instead - as the pipes on those apparently run down the inside of the 'A' columns , down the back of the electrics, then out through a hole in the bodywork - great idea!! Anyone know how they route through the car?
26th Feb 2019 6:04pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
I used strimmer cable on my D3 with good results but I couldn't even get it round the first bend on the FF! 2016 Skoda Octavia VRS Estate
26th Feb 2019 6:28pm |
Nioelva Member Since: 06 Feb 2015 Location: Kungsbacka Posts: 47 |
I had the same issue on my L322 a couple of years ago. The solution was to spray some WD40 into the drainage tubes, wait for a minute or two and then pour some hot water (not boiling, but warm/hot) down the tubes.
27th Feb 2019 7:18am |
Thanks for the responses guys, I'll give them a go and hopefully see water on the drive Steve
27th Feb 2019 3:39pm |
Izzynco Member Since: 30 Jul 2021 Location: Miami, FL Posts: 2 |
Did you ever solve this?
30th Jul 2021 11:43pm |
Hi ,
31st Jul 2021 12:06am |
Happy to sound like it’s resolved!!
31st Jul 2021 4:58am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4202 |
There is a video on Powerful UK YouTube site that shows the sunroof drainage in detail 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
31st Jul 2021 7:13am |
Broadoakboy Member Since: 23 Nov 2020 Location: Wiltshire Posts: 26 |
My issue cost £2500 of my money plus a £1000 dealer contribution. The amps etc under the passenger seat and 'stuff' in the boot need to be replaced because of a fully corroded sunroof drain. |
10th Sep 2021 1:38pm |
