![]() | Home > Maintenance & Mods (L322) > Static bending bulbs melted my lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35816 ![]() ![]() |
not sure what you actually mean..can you post pics maybe..
Alz Member Since: 27 Feb 2019 Location: Staffordshire Posts: 8 ![]() ![]() ![]() |
No it was already upgraded when I had the car |
then its an auto electrician or someone who does facelifts...
I have just read the white side lights, other people have had the same problem but it dose not say why this happens I’ve had a mate test the power going in to the lights and he is saying it’s the correct voltage so I’m now lost It dose say a lot of people remove the bulbs to stop this happening I had H8LL 35 watt bulbs in before so I think I’m going to change the bulbs to led and if I can’t repair the damaged bulbs holders I might just leave the bulbs out and live with adaptive light on the dash . I will try put some photos on |
Not very good photos but I think you can see the plastic holders have melted
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Are these the cornering lights? If so, they're not meant to be on all the time. I wonder if that's what's caused the heat problem? 2010 4.4 TDV8 Vogue SE |
Yes they are there on soon as I turn the key |
I now have both cornering lights working if I have cornering static bending light will I have adaptive head lights also because I’m unsure my car is Range Rover td8 hse LR20 how would I be able to tell if I have adaptive lights because there isn’t two ballasts on the lights and I’m thinking have the wrong lights been fitted to car when the up grade was done because I have the adaptive light flashing on the dashboard but don’t have two ballast on the bottom of the lights
firstly, you say you have a 2007 HSE variant which doesnt exist....do you have a sport??
I have range rover sport hse 2007 I have just called Land Rover and they have said my car is listed having static bending and adaptive head lights as I only have 1 ballast on the bottom of the head lights I think the wrong lights have been fitted before purchase the car seems the lights I have are ome led style head light nine afs if I have got that right when afs should be fitted |
this forum is for the larger range rover and there is a sport forum where you might get a more specific answer to your problem..
